1 members (Brian Moore),
95
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Does anyone have a picture of the 1947 2nd series dash, specifically the steering column mast mount? Can anyone confirm that the 1947 2nd and 1948 did not have a drip rail on the top of the cowl? I thought that was a 1947 feature only and they corrected it in 1948. I just saw some pictures of a 1948 cab with the smooth cowl and i may have been mistaken on when this changed. Thanks………….g | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Thanks Don, I can see from your pictures the non-indent on the dash. Do you have a better picture without the steering column? Do you have a picture of the original gauges mounting tabs? I know they are different than the 1948. Is the cowl indent smaller or just where it mounts to the dash, for some reason I thought you could tell the 1947 from viewing the mast hole from inside the engine compartment.
Do you know if the 1948 shared the same smooth (no groove rain drip) cowl as the 1947? Do you know when they changed it?
I had forgotten that they had push open instead of pull open door openers. Since it never had a mounted shifter column, the holes for the mounting will not be present either. The mounting bracket will be a one year only too. or will it? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I am hesitant to reply because every time I do I get critiques from the 30+ post wonders that inhabit the site lately, but here goes. Here is a picture of the mast hole you describe. There is a similar shaped plate that covers it on the inside. I have seen this on a couple 47's and one 48 I have owned. You can also see the smooth cowl pretty well. https://www.flickr.com/photos/advance-design_parts_co/8593171495/in/set-72157631870734114The column bracket appeared to be the same as the later models, I haven't sold it so I will look around to double check, same on the gauges as I know I still have them. Part number on the column brackets is 3686722*16 and 17. https://www.flickr.com/photos/advance-design_parts_co/8625359671/in/set-72157631870734114I have also seen 48's with and without the rain channel which was probably a running change by assembly plant. | | | | | Joined: Mar 2005 Posts: 155 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 155 | You should be able to determine if the cab is '47 or '48 from the engine compartment as well as inside. The mast hole had to be vertically elongated to accommodate the column shifter in '48. Also if the doorpost ID plate exists, '47 serial numbers begin with EP, ER and ES. 1948 serial numbers begin with FP, FR and FS. RdsLessTaken/Don This '47 mast hole is like Brad Allens. http://i1291.photobucket.com/albums/b542/RdLessTaken/RdLessTaken%20Trucks/IMG_79043_zpse102079b.jpg | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Thanks Brad and Don, that helps. I know we get a lot of incomplete answers on this board and sometimes confusing responses. My intention is to give accurate answers and when I find myself giving wrong information I try and rectify it. I thought I had seen 48 cabs with the groove, in fact I sold one. But body tags get changed and I may have identified it incorrectly.
Brad, It's obvious that you have had the parts to confirm what you say as have I. I have a garage full of Suburban/Panel/Canopy Express parts that I have purchased/removed or confiscated before they went to the crusher. I have been a member on here since 1999 and have spent more time searching then I wish to say.
For some, the SB is a joke because of misinformation. I read that on a similar site constantly and we have members on both sites that know what I am talking about. I try and do my part to be informative and accurate to dispel those comments, I will never be successful, but that's my goal. I enjoy the knowledge of people like you that do have minutia details about these trucks, because of these details people can avoid costly mistakes or wasted time figuring out what they did wrong.
I am compiling pictures to identify lot's of differences throughout out the 47/55 1/2 ton models to assist me and others in this hobby. We have several bolters' that have done the same and I have mentioned to Peggy that we should have a Stovebolt Cave for archiving these differences and making a pictorial retrieval system. We could also have some of the best posts discussions there for others to see instead of having to search thousands of documents not find this information. But as we all know, it takes time and someone who can do it, it's not fair to push it on Peggy who is already on overload.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You are welcome to any of my archive pictures if you need them. I also have quite a bit of literature for AD's I have never posted so let me know if I can help. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Thank you!  That's a move into the direction I have been going for a long time, nice to see another bolter' join in! You have my email address, let's stay in touch…………….g | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Thanks Brad, that makes sense to me now. They would need the oblong hole to install the mast, but would use the block off plate to keep the critters out and secure the mast too. The pictures of the gauges are exactly what I need to see in print. I have only seen one set before at a swap meet. ………….g | | |
