2 members (Svcattle, baldeagle),
145
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 26 Apprentice | | Apprentice Joined: Aug 2006 Posts: 26 | What's the trick to getting the sending unit out of a 69 pickup? Seemed like i may be forcing things, so I stopped and decided I'd get some good advise.
I gave up golf for this!
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Birdieall,
I have seen that ring attacked with a screwdriver and hammer to 'unscrew' it. Sometimes it takes a coordinated effort by two people smacking in unison on opposite ears. I vaguely remember seeing a piece of keystock laid across two ears and a long wrench used to twist the keystock in a 'unscrewing' direction. I don't know if this is good advice or not!
Stuart | | | | | Joined: Aug 2006 Posts: 26 Apprentice | | Apprentice Joined: Aug 2006 Posts: 26 | That is how I began attacking it but the force seemed excessive so I stopped. It's been there for 37 years maybe it a little attached to its current position.  Thanks
| | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I think what you need is a spanner. If what you are talking about is what I think, what you need is a tool that will apply pressure equally on bothe side of the nut. You need a basically open end wrench with tabs to grab the lugs on the nut or ring. You can make one easily enough even with out fancy equipment. A piece of flat stock with a drill with a hole cutter a file and time you can make what you want, Just my two bits worth, Jimmie. | | | | | Joined: Aug 2006 Posts: 26 Apprentice | | Apprentice Joined: Aug 2006 Posts: 26 |
