| | | Forums66 Topics128,096 Posts1,056,473 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 15 Apprentice | | Apprentice Joined: Jul 2007 Posts: 15 | my starter makes an awful noise sometimes when starting, sometimes it is just fine and starts smoothly. It sounds as though the teeth or splines are grinding? The truck has the stock 235, and has been converted to 12v. Is it possible the flywheel/starter was not changed when converted to 12v, and has the wrong number of teeth? or is it likely to be just out of adjustment or a bad starter?
any advice would be appreciated... i did a search but didnt see anything that fit my description.
thanks | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | onelane,
If your truck still has the stomp starter, it is probably the original 6 volt starter being run on 12 volts. This is OK and common practice. If this is true, I would pull the starter and look at the mechanical linkage from floor stomper to starter switch. This can get worn and not allow the bendix to fully engage the ring gear.
While it's out, look at the ring gear with a trouble light and see what condition the teeth are in...do the same for the bendix. It might be a situation where it's worn linkage, and a worn out bendix.
Stuart | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You probably have a worn out starter drive. It is a one way clutch & if it slips inside it makes a grinding noise. If you like to fix stuff yourself it is not hard to take the starter apart & replace it. Remove the thrust washer on the end of the shaft & tap the coller back. Then remove the snap ring & the drive . They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2007 Posts: 15 Apprentice | | Apprentice Joined: Jul 2007 Posts: 15 | thanks guys, i will check both out when i replace the 235 later this month. | | |
