4 members (54farmtruck, Danielbolt, Wooley, 1 invisible), 110 guests, and 0 robots.
Topics128,157
Posts1,056,875
Members48,456
I'm looking to upgrade my truck in many ways as opposed to few. I want to do a chassis swap I'm thinking I'm Judy not sure what would fit up under it, maybe a 2500 with a diesel? Maybe something with a big block? Have any of you gents out there messed with this on a 61?
1961 Chevy Apache 20 Crew Cab Stepside
-235ci inline 6, Carter YF2100S, SM420, Eaton HO52 w/ 5.13 on 35" BFG Baja T/As-
"BamBam"
More pix in Photobucket
A tape measure is your friend!
Yeah that's beginning to become clear. What should I be sizing up? Length times width from outer most square points?
"BamBam"
what really do you want to do. do you have a plan?
orig frame is usually the best as most later components will bolt underneath without to much problem. frame swaps a lot of time are more pain than what they are worth and by staying with the orig. frame you do not have to worry about reregistering the frame and inspections
ron
I would start with sizing up your bank account
1947 M15 Studebaker 454 4x4
1949 Chevy COE
More pix of the COE
1950 Harley FL
1958 GMC LCF 455 3x2bbl
1961 Chevy C60 Tilt Cab 327
1966 Chevy C60 Tilt Cab 496
1961 Chevy K10 sb 292
1974 Harley FXE
1979 Chevy K10 sb
2007 Harley Streetglide
I'm not that good but I'm slow
