0 members (),
348
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 40 | I'm looking to upgrade my truck in many ways as opposed to few. I want to do a chassis swap I'm thinking I'm Judy not sure what would fit up under it, maybe a 2500 with a diesel? Maybe something with a big block? Have any of you gents out there messed with this on a 61? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | A tape measure is your friend! | | | | | Joined: Jul 2012 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 40 | Yeah that's beginning to become clear. What should I be sizing up? Length times width from outer most square points? | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | what really do you want to do. do you have a plan? orig frame is usually the best as most later components will bolt underneath without to much problem. frame swaps a lot of time are more pain than what they are worth and by staying with the orig. frame you do not have to worry about reregistering the frame and inspections ron | | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | I would start with sizing up your bank account
1947 M15 Studebaker 454 4x4 1949 Chevy COE In the Stovebolt GalleryMore pix of the COE1950 Harley FL 1958 GMC LCF 455 3x2bbl 1961 Chevy C60 Tilt Cab 327 1966 Chevy C60 Tilt Cab 496 1961 Chevy K10 sb 292 1974 Harley FXE 1979 Chevy K10 sb 2007 Harley Streetglide I'm not that good but I'm slow
