8 members (68ironhead, lumbersawyer, 48jim1ton, Woodcmiami, 3B, J Lucas, Ponchogl, 1 invisible),
97
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | yesterday I was tightening my head bolts down and snapped one off at 80ft. lbs. of torque, i was going by this and was trying to reach 90 at least http://1954advance-design.com/Stovebolt-engine/head-bolt.html I don't know if it snapped off in the block very deep or if there is a little bit sticking out that i might be able to get hold of. i am going to look at it later, but my question is how do I remove this bolt if it did break off in the engine, and where can i get new head bolts? thanks in advance, Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Many times, once the stress on the bolt (i.e. the head snaps off) is relieved the shaft will simply unscrew. The bolts are available from several vendors and perhaps at your local FLAPS.
Ed
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | took the head off, and tried to get the bolt to unscrew, but it is stuck tight..... now what? Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | took the head off, and tried to get the bolt to unscrew, but it is stuck tight..... now what? Indy  using vice grips, a pipe wrench, or a welded on nut?
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | vice grips and a pipe wrench, I don't have access to a welder or I would try it. Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Rereading the first post I guess these questions come up
Were the threads chased? What if anything was used as a lube? Original bolt, but how were they coming out?
How much of the bolt is exposed now that the head is off?
Personally this is where the cheap HF wire feed is worth it. 110V. You don't have to worry about how well it works for a real welding session. Your filling a hole.
It's small and lite enough to get inside or underneath...
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Don't be in a rush here. Do you have any machinist friends nearby? The last thing you want to try is an easy-out which can make things much worse. When this is cleared up, you need to examine all your head bolts. If any did not thread nicely, they could be stretched and distorted too. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | How much of the broken broken bolt is above the deck surface? I have good luck using a left hand drill bit to get broken bolts out. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I second Don's suggestion on left handed drill bit. They tend to heat the bolt a bit while drilling and then they may grab the bolt and turn it out.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Where do you buy these left hand drills? I would like some. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I see the left handers at the local Marine and Industrial supply house.
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Many local parts stores are keeping them now. NAPA should keep them.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I get them from the local Ace Hardware store. I have also got them from the Snap On dealer. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Where do you buy these left hand drills? I would like some. Same shelf as the left-handed monkey wrenches, yuk, yuk, yuk. (We need to learn to laugh when things go bad.) Left hand bits are great except when you are trying to drill a hole right handed because you didn't pay attention to what box you pulled the bit out of. I wrote "LEFT HAND, STUPID!" on mine.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There are a lot of them listed on eBay, Here is one example.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Regarding the method of welding a nut to it, isn't there a risk of welding the bolt to the threads in the block? The current has to pass through there. | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | Rereading the first post I guess these questions come up
It's small and lite enough to get inside or underneath... i used engine oil as a lube, but i am afraid I don't understand your other two questions  . I have a little welder but it will hardly weld sheet metal,so it probably won't do the job real well. also the bolt is sticking out of the block about 1/8 of an inch. I probably will just replace all of the head bolts so I hopefully won't have to deal with this again Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | Don't be in a rush here. Do you have any machinist friends nearby? The last thing you want to try is an easy-out which can make things much worse. When this is cleared up, you need to examine all your head bolts. If any did not thread nicely, they could be stretched and distorted too. sadly, I don't have any machinist friends near me, or even a machine shop within a 50 mile radius. Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Were the threads chased? As in did you run a tap down them to clean up the threads and make sure the bottoms of the holes are clean and free of anything that may cause the bolt to bottom out before intended.
How much oil was used to lube the bolts. Look up "Hydrolock".
A small welder will do the job. Get it out a practice welding a similar size bolt, washer and nut together.
A washer over/around the broken bolt shank will keep the block protected some and give the nut a little support. A large fender washer might give room to tac to outside the nut as well as the center. (make sure you can still get a wrench or socket on it)
Welding the threads to the block would take some effort with a small welder I think, but that's why I suggest the washer first.
I'd try using some wax as soon as the nut is welded on to take advantage of the heat cycle generated from welding. I haven't tried that technique but this would be a place to give it a shot if it were me.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Another hot tip: use canned biscuit dough around the weld area to prevent metal splatter on the block. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Another hot tip: use canned biscuit dough around the weld area to prevent metal splatter on the block. Woah... you just blew my mind  What about thick pancake batter?
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Another hot tip: use canned biscuit dough around the weld area to prevent metal splatter on the block. And if you use a tig welder, you won't have any splatter and you can eat the now cooked biscuit.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | With the head off you should have enough head bolt length remaining to use a stud retractor. They are available at most auto parts store or even Sears. And EBay. Google Stud Retractor for an image.
Drew
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | "the bolt is sticking out of the block about 1/8 of an inch."
Above is the information given by the trucks owner. Seems that most guys prefer to weld a nut to the broken bolt and have given good advise how to do it. I suggested a using a left handed drill bit to drill the center of the broken bolt, usually drilling this way will spin the broken bolt out. Another method is to use a sharp punch or small chisel and slowly try to spin the broken bolt out, it takes patience and you have to be careful not to damage the metal around the bolt.
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | A method that has worked well on bolts not rusted solid.
use a Dremel tool with a cut off wheel and cut a slot across the bolt to fit a large screwdriver. You could do the same thing with a hacksaw blade but not around a sealing surface.
If your screwdriver has a hex on the shaft, great, or clamp a vice grip to it. | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | All the above suggestions assume the thread is in good shape and not galled or otherwise compromised. If the thread is seized, it's probably going to be necessary to drill the bolt out a little at a time after getting a center punch dimple in the exact middle of the bolt. I'd suggest renting a magnetic-base drill press that holds itself to the top of the block for that operation, since even a slight misalignment of the drill bit will result in a junk block. Drill the bolt out about 1/32" at a time until you get to the minor diameter of the thread, then use a tap to clear the remaining residue.
If the thread in the block is severely damaged, drill and tap the hole for a heli-coil while you're set up with the drill press. Good luck! Jerry
| | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Indy when you get it out PM me and I'll send you a bolt there are 2 lengths .....
" STUCK IN THE '50'S "
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If the remaining thread in the block was a concern, would using a stud help? | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | If the remaining thread in the block was a concern, would using a stud help? It would depend on the amount of damage to the thread. I tend to err on the side of caution where head attachment is concerned as there's very little room for error. One of my racing competitors had a flaky torque wrench and stripped one head bolt thread as he was assembling his engine. He kept going, and ended up with 6 stripped threads and damage to several others. I salvaged his VERY expensive race block with a lot of prep work done to it by making up a drill guide jig and putting HeliCoil inserts in all the head bolt holes. Did I mention he had a bad case of Budweiser fever while he was building that engine? Jerry
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | update....... i finally got it out!!! sorry for the delay, been busy. thankfully i had a spare bolt lying around that i had forgot about to replace it with. thank you all for your help, Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Yeah.... but we want to know HOW you got it out
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | inquiring minds wanna know.....How did you get it out? | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | yes, don't do this to us... | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | sorry, got busy again..... i first cut a flat side on both sides of the remaining bolt with a dremel cut off tool, then got the biggest crescent wrench i coul find and presto!!!! it turned!!!!!  Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Wait just a gall durn minutes here.... No one suggested that!!!
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | i know!! ain't I so smart!!!!!  Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Apr 2014 Posts: 4 New Guy | | New Guy Joined: Apr 2014 Posts: 4 | Irwin makes them, try lowes. and home depot, or order off the internet. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Materman: A Crescent wrench? Nice! I don't have to buy a new tool...got me some already. Good fix.
Steve H
