1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#10192 03/03/2004 1:39 AM
Junior Member
Junior Member
I know that their has to be a write up about installalion an 5 speed behind a 270 with stock bell houseing. Right now am running a B.W. 4 speed out of an 79-82 GM. Can I use the same pressure plate and T.O.B. I figured I need to replace the disc and maybe the pilot bearning. Can anybody point in the right web site or other help.
Thanks Dave
Stock and loveing it.
#10193 03/03/2004 4:37 AM
The back side of your GMC should be same as all these Chevs on this site(235/261s). The Chevy truck went to the modern trans bolt pattern in about '51 or so not sure when GMC went to that pattern. But, if you can bolt that 4 speed up your in good shape. You should first copy all the 5 speed 'tech tips' on this site and 'the Stovebolt page'. Tons of great info via the tech tips. Compare the splines from the 4speed to the 5 speed. If all measures the same which I think it will your OK with the pressure plate etc.
1946 1/2-Ton Chevy
