7 members (TexasA&M48Truck, Bill Hanlon, Shade Baby, Nhluvstruck, Brian Moore, Wally / Montana, 1 invisible),
227
Mod | | | Forums66 Topics128,087 Posts1,055,985 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | Does anyone have any tricks for removing worn down phillips screws. I'm talking mostly about those trim pieces that hold down the weatherstripping in the doorway of a 51 chevy 3100. I would just drill them out but I need to get the new screw into that hole so I need to remove the screw.Thanks---Jack | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Use a impact screwdriver ....
" STUCK IN THE '50'S "
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I've had to cut the screw head deeper with a dremel, so that it breaks off, and then redrill. I know that's not what you were looking for but it's the only method that worked for me. | | | | | Joined: May 2013 Posts: 27 New Guy | | New Guy Joined: May 2013 Posts: 27 | several ways. . . vice-grips weld a hex nut to the screw cut a deeper notch with a dremel cut off wheel and use a flathead screwdriver 'easy out' | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Try something like this. https://www.buyspeedout.com/?MID=4878676There are other brands out there like this though. I think Sears has their own. Irwin has thier own. For the future, when trying to get screws out, I'll second the impact gun idea. I have a small 12v Rockwell impmact that takes 1/4" bits, It's amazing what that thing can get out when a screw gun would just strip it. Chris | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | The impact screwdriver I've used is hand held with pressure to the left, then hit with a hammer . It used to be a necessary tool to work on Harley motorcycles .
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | best practice removing stuck screws is to first tighten them with the impact, which will usually un-stick them .... or snap off the heads
Bill | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I have a bag of assorted driver bits from HF I keep just to weld onto screws when their stuck. Sort of like welding a nut on a broken bolt...
| | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | CJSTP - I'm right there with you. I have one trim screw on each piece of door trim that is stuck. very bottom screw at the door sill. I'm not sure how much I'm going to fret over it, as the trim is very beat up and may warrant replacement. If so, It's going to get the grinder then vise grips.
I tried all the usual suspects, with zero success other than stripping out the head. I think now all that is left is drilling out the head. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Small screws are almost impossible to drill out or drill into. They are also hard to cut a slot and hard to grab onto. If you have a welder and there is some stick-up of the screw or screw head, find a washer with a hole just a tad bigger than the screw and weld it to the screw first. Welding at the washer hole area. Then weld a nut to the washer. That has always worked for me without damage to the associated trim piece. As Bill says rock the screw in and out awhile with a socket on the nut. This is, of course, after you have PB Blasted for a day or so. In this method you will have a large leverage advantage so don't break off the screw shank. Go slow and lots of back and forth with minimal torque. I don't like electric or air tools on small stuff. You have no feel or control. You will strip a Phillips head in no time. I have used a small cordless driver with a ratchet torque setting. Set it way low and let it knock. Not for the force of it but for the vibration without stripping Phillips. It will set there and buzz and finally turn....maybe.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | You folks have given me alot of ideas. I think I'll dig the dremel out of the bottom drawer and start trying some of these. Thanks---Jack | | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | I have one of those hand held impact drivers that use different bits. You hit them on the head and the bit turns slightly under impact.I cleaned out the bit slots in the screws and sprayed with pb blaster. Them impacted and resprayed. Loosened all four screws on both sides on the trim piece in the doorway on the floor.I got most of them out with a screwdriver. A couple had crust on them so I had to unscrew them the last bit with vise grips. All out and ready for cleanup.---Jack | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Just to add an idea. I decided that rather than hacking it up with a chisel, hacksaw, dremel, etc., to just take a cutting torch with a welding tip on it. I added enough heat to get the head of the screw cherry red, but not heat the strap. Waited until the screw head cooled enough to not show any color, then used the screwdriver and backed the screw out like it was in butter.
I would say you could probably have good success with a MAPP torch similar to what a plumber would use to sweat copper fittings. They sell them all over. | | |
