1 members (dunfire),
157
Mod | | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | I have a 1946 1/2 T and am looking for installation instructions for mounting the cab onto the frame.
I purchased the necessary hardware from J Carter but it does not have detailed instructions. Is there such a document? I have found great info for the bed. Thanks for any suggestions. Harold
Harold Is a restoration ever finished? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I have a 1946 1/2 T and am looking for installation instructions for mounting the cab onto the frame.
I purchased the necessary hardware from J Carter but it does not have detailed instructions. Is there such a document? I have found great info for the bed. Thanks for any suggestions. Harold What part of it do you need assistance with? The order of installation, or? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | What part of it do you need assistance with? The order of installation, or? I suppose the order of installation for all the springs, blocks, screws, etc. Photo's or diagrams would be a big help Harold
Harold Is a restoration ever finished? | | | | | Joined: Mar 2005 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 89 | Harold, 41-46 Cab mount diagram. Images
| | | | | Joined: Feb 2008 Posts: 1,123 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,123 | I have a bunch of photos I took before, during and after I removed the cab from my '46 a couple of years ago. If you can wait a day or so, I'll get these together and post a link for you. I need to get these organized better, first. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | I have a bunch of photos I took before, during and after I removed the cab from my '46 Looking forward to seeing the photo;s. They should be a big help. Harold
Harold Is a restoration ever finished? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Thanks for the images they will help in placing thepieces. Harold
Harold Is a restoration ever finished? | | | | | Joined: Feb 2008 Posts: 1,123 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,123 | Here are the photos. These show the '46 Half Ton cab mounting hardware before and after removal. HERE 1 HERE 2 HERE 3HERE 4 HERE 5 HERE 6HERE 7 | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Thanks for the photo's. Thse plus the Diagram will make my job easier. Harold
