1 members (Otto Skorzeny), 85 guests, and 1 robot.
Topics128,162
Posts1,056,941
Members48,458
I have a lever action shock from a 1949 Chevrolet 3100 series pickup. It is a single lever action shock. I have taken the end cover off and found that the piston is rusted and ceased in the bore. Can this piston be removed to reused or am I SOL and need o find another shock that is not ceased?
1970 VW Beetle
Probably going to have to find another shock. I'd try soaking the assembly in something like PC Blaster and see if it might come out. Not sure, but if there was room to run a brake wheel cylinder hone in the bore ahead of the piston might remove the corrosion ahead of the piston. if the cylinder is rust much, it would probably have to be sleeved.
i took mine off and threw them under the work bench.....they still work but I switched to tube shocks on my 46 1/2ton
I would say that if it is that rusted, it is junk and move on. I think Whitedog just posted what you need in the for sale section.
Lots more pictures
Yeah converting to tube shocks used on the later AD trucks would probably be the best way to go.....
Just saw a pair on eBay. Don't give up so soon.
