7 members (LAROKE, Stovebolt48, Tronman, Bwana-Jim, Otto Skorzeny, Lightholder's Dad, 1 invisible), 72 guests, and 3 robots.
Topics128,042
Posts1,055,511
Members48,424
#1018400 03/31/2014 5:39 AM
How hard is it to press out front leaf spring bushings on a 54?
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Check this "Tech Tip"
http://www.stovebolt.com/techtips/bushingpuller.htm
I just used a 1/2 inch bolt but otherwise the same process.
Steve H
This was an remover/installer special made for that Chris but a
socket or piece of tubing, some threaded rod or long bolt and
washers would do the same thing:
http://www.pbase.com/dennygraham/image/122328123
DG
Denny G
Sandwich, IL
Thanks guys. I recently purchased a front clip for the pupose of using the leaf springs. After I got them home, I asked myself, "Why did I do that?"
Not wanting to admit defeat, I may buy a bushing/shackle kit and see how it goes.
I have an old U-joint press that may help in the process, we'll have to see.
Chris
"The Fake Truck"
I took mine into the shop on post and had it done in about an hour which included all bushings in leaf springs and brackets. It is not hard if you have a press like i used.
