1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | How hard is it to press out front leaf spring bushings on a 54? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | This was an remover/installer special made for that Chris but a socket or piece of tubing, some threaded rod or long bolt and washers would do the same thing: http://www.pbase.com/dennygraham/image/122328123DG
Denny G Sandwich, IL
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Thanks guys. I recently purchased a front clip for the pupose of using the leaf springs. After I got them home, I asked myself, "Why did I do that?"
Not wanting to admit defeat, I may buy a bushing/shackle kit and see how it goes.
I have an old U-joint press that may help in the process, we'll have to see.
Chris | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I took mine into the shop on post and had it done in about an hour which included all bushings in leaf springs and brackets. It is not hard if you have a press like i used. | | |
