1 members (Ponchogl), 182 guests, and 0 robots.
Topics128,101
Posts1,056,180
Members48,436
I installed Dolphin gauges in my 1961 Chevy C10.
I am using the original fuel tank behind the seat (and the original sending unit).
My Dolphin Fuel gauge reads about a half a tank of fuel when the tank is full. I called Dolphin tech help line.
I was told my original sending unit is a 0-30 OHM unit. And the Dolphin gauge needs a 0-90 OHM sending unit.
So I need a sending unit that will fit my tank which will also work with this Dolphin gauge.
I was told that GM used 0-90 OHM sending units from 1964 trucks and after. I am not sure if my source is accurate with this information.
Can anyone verify if all I need to do is find a sending unit from a 1964 and after? In other-words, what sending unit will work for my original gas tank AND work with my new Dolphin gauge?
Thanks in advance,
Brian
Your wife called & said
"buy whatever you want"!
1961 Chevy Apache 10 Restoration Photo Album
in the Gallery ...
My 1961 Chevy Custom Apache 10 SWB
Brian,
All the scoop you got was correct. I don't know what year GM sending unit would fit best, but if all else fails, Stewart-Warner has universal units in 90 ohms....I think!
EDIT. More research indicates the 90 ohm sender was used in '65 and later, so it might take a hands on check with a meter to be 100% positive. I have enclosed a interesting link on sending units.
http://yogisinc.com/results.cfm?Category=376
Stuart
Brian,
I sent you a email, did you get it?
Jake
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
