7 members (Leo, 1955 1 Series, Mike B, Danielbolt, Wally / Montana, Bill Hanlon, 1 invisible),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,863 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 6 New Guy | | New Guy Joined: Mar 2014 Posts: 6 | Hello all. New to the forum and looking forward to chatting and learning while working on my '59 4100 series flatbed. I have replaced the master cylinder, but i am aving trouble finding wheel cylinder replacements. The rears are Twinplex and the fronts are Duo-Servo. Does anyone know of a good source to order on the internet? I would rather buy new than rebuild. Thanks | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | You might wanna try NAPA first. I bought mine for my 56 3100 there was supprised they had a listing and some parts on hand. Try these guys P&O brake 702-384-2530 www.customfriction.comOr Brake & Equipment Warehouse Auto Parts 800-233-4053 www.brakeandequipment.com
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 59Viking, if my memory serves me correctly, your front wheel cylinders are no longer available, but we did manage to find another wheel cylinder with a different style of hose attachment that would bolt on and do the job. I wish I was better with the confusilator and could find the old post for you, but alas I'm not smart enough for these new fangled contraptions. Your rear wheel cylinders are Raybestos p/n WC18196 one left at RockAuto $16.00 and p/n WC18197 one left at RockAuto $3.26, I realize you will need two of each and I will try to cross the number at the Napa site. I suspect your rear brakes are the type with the wheel cylinder crossover line inside the drum, DO NOT THROW THOSE LINES AWAY THE NUTS ON THEM HAVE A DIFFERENT PITCH THAN STANDARD BRAKE LINE NUTS. If the lines themselves are damaged you can transfer the nuts to standard tubing and make your own crossover lines, hope that helps. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 59Viking, the Napa p/n for the rear wheel cylinders are UP18196 $35.49 UP18197 $35.49, hope that helps. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 59Viking, with the help of my partner I found the old post, hope it helps. the following are Raybestos numbers and prices are from RockAuto in U.S. dollars. A little explanation on the front wheel cylinders, the originals are no longer available, back in 2012 fclaridge was looking for them also. I suggested that he try the p/ns I'm giving you, which he did and photo documenteted their installation. The only difference between the two wheel cylinders is the angle that the hoses attach to the wheel cylinders. Master cylinder MC21698 $127.79 Front wheel cylinder left WC19091 $18.01 Front wheel cylinder right WC19090 $11.00 Rear wheel cylinder reverse WC18197 $27.79 Rear wheel cylinder forward WC18196 only one left @ $3.79 Front brake hose BH36548 $16.53 Rear brake hose BH25664 $27.79 this is the hose for the H.D. rear axle, as they showed no stock for the standard rear axle hose p/n BH4492. You will have to order two of each of the rear wheel cylinders, and as you can see they only have one of one of them left in stock, also you will need two front brake hoses, hope that helps.
| | | | | Joined: Mar 2014 Posts: 6 New Guy | | New Guy Joined: Mar 2014 Posts: 6 | Wow! Great information from all! Thank you so much for the help - looks like i have plenty to do next weekend. Thank you again!!
Dan | | |
