7 members (MNSmith, TUTS 59, Goach2, LAROKE, Gray_Ghost, Lightholder's Dad, Cletus1950),
77
Mod | | | Forums66 Topics128,173 Posts1,057,041 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | We recently picked up a 1952 Chevy 3100. Didn't know anything about the engine until it was home and started researching. The casting number is 3738307 which I have found indicates a 235 from 1958-1962. During this time, it appears that casting number was used on trucks from 1958-1959. Is there a difference between the truck version of this casting and the car? Any other ways that I can identify what I have? I'm trying to replace the fuel pump and when I look up the part, I see cross references for different vehicles. I need to buy an manual for the engine as well as ordering parts in the future. Any other way I can identify where this engine came from? Here is a picture of the fuel pump that I pulled... Fuel pump Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Post the numer stampped on the pad just behind the distributor
Someone will be able to tell you from that s/n | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Will do. Don't have that on me at the moment, but I will get it in an hour or so. Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Ok, it's either FIOIIA or F1011A So, from looking here it's a 1958-1960 passenger car 235? I am assuming the "A" is for passenger car and "J" would have been for the truck. And ours is a 4 speed but have no clue where that may have came from if "A" implies a three speed. If this is the case, are there any other codes to pinpoint the year? And then back to the main question, what are the differences between the passenger car version and the truck version of the 235?
Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What you have would be F1011A. It was not unusual to see an "I" in the stamping code used as a "1". It breaks down as a Flint produced Passenger engine, built on November 10. Another thing to check to pin the year is the block casting date, which would be found on the passenger side of the engine, near the starter. That date is usually a bit earlier than the assembly date, but should be within the same year.
Bill Burmeister | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The car 235's had hydraulic lifters and the truck versions had solid lifters.
| | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Do I have to remove the starter to find the block casting date? Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No, you should be able to see it with the starter in place. You may want to shine a flashlight in there to make things easier to read. The will be two different numbers, one with a month/day/year format, the other will say something along the lines a "CON 1". The second one is the number of the line the block was cast on.
Bill Burmeister | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Some where in time the front motor mount changed. So if it is in your 52 truck that has been addressed.The fuel pump is the same except for the inlet and outlet routing. So I just get the truck one cause it fits and lines up with the fuel lines. I no longer run vacuum wipers so I get the "cheap" pump. Car engine has hydraulic lifters so that is cool. Only need to know when they get changed and are mostly set and forget. If you have had no issues with the starter and flywheel then you have a matched set. Either 6 volt starter and a 6 volt flywheel or the same for 12 volt. Again no real issue there just replace what you have when needed. If you have the straight vacuum advance then that is for the truck as well. Looks like a truck fuel pump to me. Follow what the others have advised and get the right year for the engine. Keep it all in a notebook and keep that with the truck. That way you will only have to do this one time. Enjoy!
Steve H
| | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Some where in time the front motor mount changed. So if it is in your 52 truck that has been addressed.The fuel pump is the same except for the inlet and outlet routing. So I just get the truck one cause it fits and lines up with the fuel lines. I no longer run vacuum wipers so I get the "cheap" pump. Car engine has hydraulic lifters so that is cool. Only need to know when they get changed and are mostly set and forget. If you have had no issues with the starter and flywheel then you have a matched set. Either 6 volt starter and a 6 volt flywheel or the same for 12 volt. Again no real issue there just replace what you have when needed. If you have the straight vacuum advance then that is for the truck as well. Looks like a truck fuel pump to me. Follow what the others have advised and get the right year for the engine. Keep it all in a notebook and keep that with the truck. That way you will only have to do this one time. Enjoy! Thank you! We have had some issues with the starter/flywheel. Sometimes the it will engage and turn over the motor with no issues. Other times, it "grinds" making that same noise you hear when you try to start a motor that is already running. I was going to try to pull the starter to see if there was any thing that looked "odd" (don't know what exactly I would be looking for) and in doing so, hopefully see the date stamp on the block. From pictures I have seen of where it's located, the starter is blocking where it would be. Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Jul 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 54 | It sounds to me like your starter/flywheel problem is your ring gear on the flywheel, your engine has a tendency to stop in the same place, therefore it is started in the same place on the flywheel, after 50 or so years the teeth on the ring gear will start to wear and then will not fully engage with the starter drive gear, if you turn the engine over by hand past the wear points it should engage the starter, the cure is simple replace the ring gear, the process is a bit of a PITA, you will have to drop the transmission, remove the clutch and the flywheel. Keep in mind that you may have a six volt starter and flywheel on your truck, there is a difference from 6 volt and 12 volt when it comes to starters and flywheels. | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | I think if someone has not mentioned it that the car motor had a fiber cam gear and the truck had an alumumin cam gear.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Thanks. We are going to try to pull the starter this weekend to undercover the date stamp on the motor as well as determine what may be causing the grinding. Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Ok, we pulled the starter and the date stamp says J 8 7. Now I can't seem to find the site that tells you how to read this. Any help? Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | F1011A engine serial numberF = Flint MI 10 = Oct 11 = 11th A = car 235 with a 3-speed transmission It would have hydraulic lifters, if 1958 J 8 7 block date codeJ = 10 = November 7 = 1957 3738307 block casting code Would be 235 used in 1958-60 cars and trucks (and could have had been used with hydraulic or mechanical cam/lifters) Maybe that block was also available late in 1957? Similar combination of codes were found in this other discussion board. | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | I thought I remember seeing somewhere that the second position was the year. That would make more sense making it a 58 which lines up with the casting numbers. Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Being a late in the year casting date for 57 it could be a 58. The way to tell if it is a 58 would be if it has center side mount provisions, 57 did not.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Being a late in the year casting date for 57 it could be a 58. The way to tell if it is a 58 would be if it has center side mount provisions, 57 did not. How would I identify this? Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | New car models typically come out in Sept of the PREVIOUS calender year. So a 1960 model vehicle could have a motor from Sept-Dec 1959.
| | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Thanks. That makes sense. Ron and Ryan Hill 1952 Chevy 3100 | | |
