0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | The dome light of my 1958 1/2 ton will stay on all the time when it is connected. I have checked out the switch and it seems to be ok. The only thing that I can think of is that there is no gasket seperating the metal light from the metal of the truck. Could this be it? Thanks
Greater love have no man than this, That he let his wife drive his truck to the grocery store. ........
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 8thairforce, That could be a possibility, but I find it tough to believe Detroit relied on the gasket to insulate the fixture. My guess would be the wire from light to door switch has found a ground through wear or pinching. Does this sound more plausible. EDIT. This is assuming this truck has a door switch! Stuart | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 8thairforce,
Poking around in this forum revealed this...your dome light is powered on one side and is grounded through a rheostat in the light switch on the other side. This would mean that the rheostat supplying the variable ground is defective, or that the wire is finding ground before it makes it to the switch. It would seem to me that the lamp holder proper must be insulated in the assembly and shouldn't rely on the entire fixture to be insulated from the body.
If you can identify the dome light ground wire at the light switch, you can disconnect it, and if the light goes out it means the rheostat is bad...if it doesn't, it would indicate a short to ground in the wiring somewhere.
Stuart | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what Stuart said ... the 2nd time the switch provides ground the light has power alla time Bill | | | | | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | No door switch. According to the headlight switch wiring there are two wires from the headlight switch to the dome light a white one and a ribbed white one. The white goes to ground while the ribbed goes to the switch. I disconnected the white one (ground) and the light still stays on no matter what position the headlight switch is in. If I understand you correctly I am looking for a short in the ground wire ( white one ) somewhere. Thanks
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the white wire goes to a ground terminal on the switch, which actually gets it's ground from the rotary knob, one way dims the dash lights, full the other way puts a ground to the dome lite - the other wire is supposed to be orange, maybe with a white runner, and it goes to the switch terminal labeled "D" as in dome, which should be hot anytime
if you disconnected the ground wire from the switch and the light stays on, then you've got a short along the line somewhere, an ohm meter from the switch end of the wire to the light socket should confirm that - prolly a wear spot up the windshield pillar which is pretty raw inside, but it may be at the light
Bill | | | | | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | Thanks my friends. I'll let you know what I discover.
