1 members (78buckshot), 106 guests, and 3 robots.
Topics128,187
Posts1,057,212
Members48,465
Does anyone have a pic of these springs or dimensions? My truck didn't have them.
H Online: Content
Look at Tim Sheridans site, he has lots of pictures, here is where to look, the pictures are not to far down in this link. I could not find original springs, tried all over to get something suitable with no luck. What I settled on for my 41are the springs out of the tie rod ends, maybe someone else has a source but that is what I did. I had lots of them laying around after rebuilding mine. Hope that helps. Dave
http://www.46chevytruck.com/FAQ.htm
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
The spring wire is rather thick, 1/4 diameter if I recall correctly and the OD of the coil is larger than the springs in the draglink. I never could find any true comparable springs. Unfortunately it is one of the items that often gets pitched when a farmer/bubba replaces an engine. They show up once in a while though, keep hunting.
Lots more pictures
I just got done doing my 53 GMC support and the springs look a lot like SBC valve springs only shorter .You could take them and shorten two of them.
Pete
I am using valve springs from a corvair (smaller low horse power 1960-63 engine valves).
