0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 16 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 16 | I am not sure how the oil seals are installed on my 48 Chevy 3/4 (full floating axle). Which side goes in first? I am guessing that the seal is installed so the part number is visible. Oil seal is SKF #28426 your help is much needed and appreciated. I have searched on the internet for info but I am not able to find and answer. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I think the part number is always on the back side, but the real way to tell is the sealing lip goes toward the bearing. | | |
