| | | Forums66 Topics128,062 Posts1,055,847 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | What size of fog lights were used on a 1951 Chevrolet truck back in the day ?
I always see different sizes for sale at swap meets.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Mine is a '48 but it had a post on the bumper attaching frame for a fog light. The top of the post had a concave ball-joint type of shape. I don't know if it was stock. I bought fog lamp and casing which would mate with the post at a Great Falls swap meet. The 6-volt lamp was burned out but I installed it just for the look. When I went to 12-volt, I found a 12-volt, 5 1/4" lamp that would fit the casing perfectly! NAPA #4412A. Here are pictures of the lamp and the light pattern. I did lower the aim a bit. Fog Light Fog Light Pattern - 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Brad, Thanks but I was talking about the brochure you posted. Sorry I did not make my question clear. (I edited my previous post). Harold
Harold Is a restoration ever finished? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Brad, Thanks, I will appreciate anything you find. Harold
Harold Is a restoration ever finished? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Thanks for the information. It is great to have documentation when you show these old pieces of art. Harold
Harold Is a restoration ever finished? | | | | | Joined: Jun 2009 Posts: 789 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 789 | I picked up this set of NOS Guide 5-3/4" fog lights and installed them on my 1/2 ton truck. Please see the link below to photos in my Photobucket album. http://s160.photobucket.com/user/st...20Guide%20fog%20lights?sort=2&page=1Please note that box label reads for "medium and heavy trucks" AND the instruction sheet is from 1946. With that stated, I am not sure how appropriate this set of lights is for the A.D. truck. Nevertheless, I like the look. I am using a vintage lever-type switch that is maroon in color; not the switch in the box. I am also using black wire with a green tracer and not the wire as pictured. Any thoughts…other than me perhaps adding confusion to this topic? | | | | | Joined: Nov 2012 Posts: 257 Haunting the SBP since 2001 | | Haunting the SBP since 2001 Joined: Nov 2012 Posts: 257 | http://s160.photobucket.com/user/st...20Guide%20fog%20lights?sort=2&page=1 Luke. Sounds like you may have been bamboozled into thinking those Guide 5 3/4" lamps are correct by a slippery ebay seller, as GM part # 929890 {in your pictures} is actually a GM part # listed for the 1939 Chevy cars & trucks. The boxes & the lamps you pictured are definitely not correct for the 1947-1955.1 A.D trucks and the lamps are not correct for the 1939 Chevy. Anyone can cram a set of lamps in an old box & claim they are NOS & correct | | | | | Joined: Jun 2009 Posts: 789 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 789 | Interesting and confusing! Nevertheless, I have these lights on my truck because I like the look/size. Can it be determined for what years the 5-3/4" Guide fog lights were correct for our Stovebolts? | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Thanks for all the information !!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
