2 members (JeffA, FishinToms53),
170
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,938 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 178 Shop Shark | | Shop Shark Joined: Dec 2013 Posts: 178 | My 3600 is rust hole free, so I'm thinking of just lifting the cab enough to paint the frame, under the cab and to replace any bushings. Only problem is I'm by myself in the garage. I will have removed the front clip by then, and tips/advice? Photobucket3
Have you ever noticed that anyone driving slower than you is an idiot and anyone driving faster than you is a maniac? - George Carlin
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | You're not the only one... Being alone in the garage isn't the problem. Not thinking safety first when lifting and blocking things up is. I always try to knock the truck off the stands before I get underneath it... If I can rock it I don't
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | The way I did it was to pass a length of 4x4 through the cab (my doors were off), put holes near either end of the 4x4 for a length of chain to pass through, then lift the cab up by the chain with a come-a-long attached to the rafters. | | | | | Joined: Dec 2013 Posts: 178 Shop Shark | | Shop Shark Joined: Dec 2013 Posts: 178 | I like it Tom. I wonder if I could use a stout tow strap to do the same thing as the 4x4 and hook it to my come along. That way maybe I could leave the doors on. Any idea what the cab weighs?
| | | | | Joined: Mar 2002 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 53 | I did a search a while back and came across an adaptor that attaches to an engine hoist. Something to try
Clem 59 Chevy 3600 New Hampshire
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | First make sure your overhead beams(rafters) can safely support the cab. Another option since you say you only need to lift it a little and I assume not rolling the frame from under the cab is to just use a floor jack raising each side a little at a time and support the cab with four jack stands.
Drew
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I did mine pretty much the same way as Tom did. Used a 4 x 4 timber and a tow strap to pick the cab up with after removing the doors ect.... I used a chain block hooked up to the H beam.
John | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I installed my cab by myself, ...pic... . I don't recommend it but wife needed her parking spot back.
| | | | | Joined: Dec 2013 Posts: 178 Shop Shark | | Shop Shark Joined: Dec 2013 Posts: 178 | Wow Brad! Now I wish I hadn't sold my picker at that garage sale. Dagnabbit!
| | | | | Joined: Dec 2013 Posts: 178 Shop Shark | | Shop Shark Joined: Dec 2013 Posts: 178 | New wife here, hav'nt given her a spot yet! Yet...
| | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | use a engine hoist . Build a frame from door to door & out both windows if they are off .hoist in one of the doors (use the top of hoist) .... worked for me ...If I did it again I would drill hole in floor 4x4 under floor and hoist inside the cab ....
" STUCK IN THE '50'S "
| | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Also build a frame for under cab, use floor jack ...
| | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | Do not lift on the pinch welds through the windshield opening and rear window like that. Lift like the factory did through the door openings on the upper sill. You could do like the one fellow that said he lifted using garage beams, or with the cherry picker, I used the cherry picker deal and 2x6 s bolted together and to the cherry picker I wish there was a way to post pictures here I'd give posting them a go.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | First make sure your overhead beams(rafters) can safely support the cab. How would one go about that?  Trusses, by design, support loading from the roofing surface. So all the upright truss memebers are in compression. If you use the lower truss cross timber to try to lift objects in your garage you are effectively putting the upright truss memebers into temsion, which is now trying to pull the truss members apart. Depending on how the members are fastened together this may actually tear the truss members apart. Have folks done this? Yes. Have I done this? Yes  (For a Jeep hardtop, which is very light.) The last thing you want is to have to do structural repairs to the roof trusses of your house, when what you really wanted to do was work on your truck.  Using floor jacks or an engine hoist is a much safer and more logical method. By far the least expensive way is to get (3) folks over to help and simply lift the cab off the frame. Have fun and be safe out there!  | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | I installed mine recently using camper jacks and boards under the cab. Scott | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I built a gantry crane for engine and cab hoisting. I use a chain hoist for the engine and a wood frame placed through the door openings and ratchet straps for the cab. Here is the crane setup for engine hoisting. I am now with crane and I broke it completely down and stored it under the house for future use.
| | | | | Joined: Dec 2013 Posts: 178 Shop Shark | | Shop Shark Joined: Dec 2013 Posts: 178 | Scott- I think the camper jack solution is great, I wish I still had my Dads set. darn.
| | | | | Joined: Mar 2010 Posts: 58 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 58 | | | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Without the front clip attached I used two 2x4's and two ladders and raised it one side at a time, rolled the chassis out and then lowered the same way.
I did have blocks on the steps of each side so I was only moving 6" at a time. Worked fine.
Good luck.
36 Chevy 1.5 ton - rusting away 52 Chevy 3100 - in progress 72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I would like to chime in with some technical feat of amazement, but the way I figure it, that is what friends and relatives are for. The cab is on a cart that I use to go from Sandblasting right to the basecoat/clearcoat, so when the time comes its all ready, the PLAN is to make a few phone calls with a beer incentive.  | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | 66 rollback - Is that a HF g crane? Looks to be working fine. Any feedback on it, I don't think I can buy the steel and parts for the same price.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Dec 2013 Posts: 178 Shop Shark | | Shop Shark Joined: Dec 2013 Posts: 178 | Wow what a set up, I especially like the extended forks on the lift (just in case).
| | | | | Joined: Mar 2010 Posts: 58 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 58 | It is from Harbor Freight. I don't have any complaints other than the paint faded badly when it sat out in the sun for a year or so. I have used it quite a few times - multiple body removals and engine swaps. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | I would second what several have said....beer. Also toss some ribs or steaks on the grill. Call up 2-3 friends/neighbors/etc. and invite them over to sample the meat and have a few cold ones. Once you get them there, "hey, could I get you guys to help me with something real fast". Works every time. Just be all set to go when you get them there so all they have to do is walk in, lift, and get to drinking beer. It also helps if you have buddies that are interested in your project. Sometimes they get to participate by proxy. Just be careful, sometimes, they end up coming around too often to participate. | | |
