| | | Forums66 Topics128,026 Posts1,055,409 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 12 New Guy | | New Guy Joined: May 2004 Posts: 12 | I just bought a 250 to go into my 65 c10.it has an electronic dist. in it . I would like to know if I can use it.It has three wires coming out of it one is red, one is pink, one is black. please help. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I use one on my 250 manufactured by Mallory. It would help to know what kind of distributer you have, O.E.M or aftermarket. Coil in cap or other.
| | | | | Joined: May 2004 Posts: 12 New Guy | | New Guy Joined: May 2004 Posts: 12 | It looks as if it,s O.E.M. with coil in cap. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Sounds like the 3 wires you mention should have a connector on the end that plugs into the distributor cap. The connector is index and will only plug in one way. If you do a search you will find many posts on installing the HEI distributor. What it comes down to is you need to replace the wire to the old coil with a 10 awg wire. The yellow wire for solenoid is no longer used, it was the 12v bypass for starting. There are two connection on the distr cap one marked bat. and the other marked Tach. That should get you into the ball park.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
