0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#101732 07/21/2007 12:21 AM
I just bought a 250 to go into my 65 c10.it has an electronic dist. in it . I would like to know if I can use it.It has three wires coming out of it one is red, one is pink, one is black. please help.
#101733 07/21/2007 2:40 AM
I use one on my 250 manufactured by Mallory. It would help to know what kind of distributer you have, O.E.M or aftermarket. Coil in cap or other.
#101734 07/21/2007 6:54 PM
It looks as if it,s O.E.M. with coil in cap.
#101735 07/21/2007 8:37 PM
Sounds like the 3 wires you mention should have a connector on the end that plugs into the distributor cap. The connector is index and will only plug in one way. If you do a search you will find many posts on installing the HEI distributor. What it comes down to is you need to replace the wire to the old coil with a 10 awg wire. The yellow wire for solenoid is no longer used, it was the 12v bypass for starting. There are two connection on the distr cap one marked bat. and the other marked Tach. That should get you into the ball park.
Larry
I don't own a vehicle that isn't old enough to drink.
