2 members (Hotrod Lincoln, Hush), 58 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#101722 07/20/2007 8:35 PM
the dimmer part if my light switch that controls the gauge lights im guessing is out cause i have no dash light, i have a "bright" light indicator but no dash lights, all bulbs replaced with correct new 6v bulbs.
question can i run the power wire from the dash light and put it with the headlight plug???? im thinking that way they would come on with the headlights.?????
plan on getting a good switch later will this work as a part time switch???
nothin like ol' Chevy iron..keep it goin
1948 Chevy Loadmaster Flatbed
#101723 07/20/2007 8:41 PM
Yes it will, you just wont have the dimming feature for the dashlights.
#101724 07/20/2007 8:52 PM
AWSOME.... thanks thats the project for tomarrow... dont care about dimmer, just want the dash light on when im crusing around, thanks "delux"
#101725 07/20/2007 9:11 PM
Youre so welcome48. Please make sure you disconnect the battery before you get into this.
Dont want no fireworks under the dash.........
#101726 07/21/2007 12:05 AM
In these situations I usually just run a jumper wire from one side of the rheostat to the other. That way the lights operate as normal, sans the dimmer.
1960 GMC Panel w/ 305 V6, 4 Speed TV Repair Van "The Monitor Lizard"
1961 Chevy Apache 20 283, 4 Speed, Hydrovac
www.picturetrail.com/starchief
#101727 07/21/2007 2:47 AM
Since you are going to most likely pull the switch to get at the 'master' wire to your dash lights you might as well take a look at the switch to see if it is indeed the problem. It might just be a loose wire. The guys here will jump at the chance to help you solve your problem. You just have to be their eyes and hands. A voltmeter or testlight are a big help and remember to disconnect your battery before poking around to much.
#101728 07/21/2007 3:26 AM
Your headlights are protected with the thermal breaker built in to the headlight switch. Justin's suggestion may be just the thing here because often times old wiring does not like to be dislodged and rerouted.
1951 1 Ton Completed
#101729 07/21/2007 11:39 PM
I HAVE DASH LIGHTS!!!! AWSOME ran the dash wire to the headlight terminal and presto!!! awsome dash lights.... thanks alot guys....
