0 members (),
68
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 53 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 53 | I picked up an original ignition switch from ebay. my question is in a 58 fleetside standard maodel, did it have the starter swith floor mounted, when i picked the truck up the po have put a v8 and auto trans in it, a very bad job. Now i don`t have a clue as to the starter set up. the switch is basicly an on/off switch. any info. Thanks mike Bourg | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the truck came with the 235 it had the foot start and the simple on/off switch - if it had the 283 it was equipped with the acc/on/off/start style switch - the correct V8 switch is available from the repro vendors ....
Bill | | | | | Joined: Jun 2007 Posts: 53 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 53 | Thanks bill, i suspected something like that,Mike | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | - the correct V8 switch is available from the repro vendors .... To add to this.......That is the only switch they carry. Anyone needing the 6 cyl switch, don't bother ordering from them. Send Mike a PM and buy his. | | |
