6 members (sron48, 55shaker, Bill Hanlon, Lightholder's Dad, JW51, Forty9), 196 guests, and 7 robots.
Topics128,080
Posts1,055,956
Members48,430
#101666 07/17/2007 2:07 PM
Junior Member
Junior Member
66 Checy Stepside.
Removed both rear tail light to paint the housing. Reinstalled and one side does not work as a turn signal. Other side works fine Brake lights work OK. Mayby I reversed the wires? Any ideas?
Also on a side note...are back up lights requirded by law?
James T
www.fixmyprinter.com
But honey...its for us!
#101667 07/17/2007 2:52 PM
Brake and turn signal are on the same wire for each side, so if you have brake you should have turn. Check that the bulb is seated correctly.
Backup lights were an option in 66, so not required by law.
Larry
I don't own a vehicle that isn't old enough to drink.
