| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 31 Junior Member | | Junior Member Joined: Jul 2007 Posts: 31 | 66 Checy Stepside.
Removed both rear tail light to paint the housing. Reinstalled and one side does not work as a turn signal. Other side works fine Brake lights work OK. Mayby I reversed the wires? Any ideas?
Also on a side note...are back up lights requirded by law? | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Brake and turn signal are on the same wire for each side, so if you have brake you should have turn. Check that the bulb is seated correctly.
Backup lights were an option in 66, so not required by law.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
