4 members (37 GC, IHPWR, Hotrod Lincoln, NJC), 141 guests, and 2 robots.
Topics128,141
Posts1,056,780
Members48,454
#1015936 03/21/2014 9:29 PM
Hi
I am upgrading a 54 1/2ton to a dual master cylinder. I am also replacing some other stuff along the way. I am having trouble finding fittings. I am trying to find replacement fittings for the rear brake cylinders. I don't think I can get the old block fittings so I am looking at using a banjo fitting. Has anyone done something similar? Is there a good place to find these things. An internet search wasn't all that helpful. I am pretty sure that I can replace the wheel cylinder with a '55 and on which, I believe, will fit and uses a direct double flare into the cylinder. But only if I can't find anything else.
Maybe this is what you need.
oldchevytrucks.com
http://www.oldchevytrucks.com
Part numbers MEE244 and MEE245
' Offline
Jim Carters - Chevy of the Forties - The Filling Station - lots of other sites, shop around.
I'd replace everything: Wheel Cylinders - Fittings - Banjo Bolts - Brake Hoses & metal brake lines.
Sample of some brake parts for your 1954 Half Ton
below @ photobucket.
Everything you need is available aftermarket.
http://i669.photobucket.com/albums/vv57/glp0329/halftonBrakeParts_zps1c7b907c.jpg
http://i669.photobucket.com/albums/...rts/Half_Ton_Connector__zpse83068b0.jpeg
http://i669.photobucket.com/albums/...s/HalfTonwheelcylinders_zpsdf865c54.jpeg
George
in
New Jersey
1954 3600
Now cruising in
The Passing Lane
