| | | Forums66 Topics128,148 Posts1,056,811 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 8 New Guy | | New Guy Joined: Sep 2010 Posts: 8 | I have a 1954 1/2 Chevy panel truck no motor or Trans or rear end or springs . I also have a 1980 Chevy 1/2 ton in good shape with an automatic that I perched as a donor . I have perched a mustang two front end kit. But could use it in a dif rent project. I have skills and a big shop. Should I keep the original frame or swap it out for all the chasses in the 1980? On anuther form I was toled that the later truck was to wide And I heard it moor than once. The 1980 truck fram is 34" wide. The 54 is 44"wide | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | It is not so much the frame width, as it is the width of the rear end and the front suspension. You need to measure from the wheel flange to the wheel flange on both the front and rear and you will see the difference. The 80 truck is wider.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | Hey BillE Are you looking for a daily driver type vehicle or occasional driver vehicle??? If you want a driver than do the swap...you may have to find narrower rear end as that era truck the rear ends are wider than your panel truck is. Take a tape measure and see what the out to out is on the 1980 rear end and then measure the out to out on the fenders of the panel truck... The more modern chassis will be much easier to find parts for...your local NAPA should carry a lot of those parts still.. Good luck with your project MikeC 1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | Would a slight body lift clear the fenders for a late 60s thru mid 80s axles? How much lift?
| | | | | Joined: Mar 2014 Posts: 40 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 40 | My cousin runs a rod/custom shop.He has done both,but left up to him,will always keep the original frame and adapt modern running gear to it. | | | | | Joined: Jan 2012 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 162 | Keep your original frame and update the suspension. Straight axles rule!! JMO.
Mitch | | | | | Joined: Apr 2008 Posts: 99 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 99 | BillE, You will get many good suggestions on which way to go, you’re the one to decide; it's your Truck. Depends a lot on what you want. The power train you pick will help point you in a direction. My direction was dictated by what I wanted, fuel injected V8,headers, 14 bolt rear and Dana 60 4x4 front. Wheel base vs/ 54 Panel, you have to shorten a full size donor, Chevy short bed frames are closer. The width on the donor gives you a lot of advantage, if installing a V8, steering is on outside, but you will need to make a decision with tire width, pedal, Master Cylinder location. The 54’ frame is almost flat under the body back to front vs/ the 80’ frame drops under the cab close to 5”. That can be a 5” body lift depending on how you approach mounting the body to the Donor frame. Good Luck with your project
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | The fullsize pickups have a much wider track width (tire center to tire center) and as a result the wheels tend to stick out a bit. I prefer the S-10 swap, but on a panel it can take some tricky figuring to not lose so much floor. I think I lost 2 or 3" of box height on my S-10 swap. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Your 1980 frame is too big. It is easier to swap a front clip (say, mid '70s Camaro) to get PS, power disc brakes and SBC engine mounts. No worries about cab/box mounts.
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Camaro and Trailblazer are both too wide in the front. Nova or 80's Malibu is narrower. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Suspension Measurements
REAR SUSPENSION: The following is a general list of rear ends and their dimensions to help narrow the search for a possible candidate to replace the torque tube rear end or just get a better set of gears for highway driving. Advance Design Trucks seem to be using rear ends with widths ranging from 58"- 62". I'm not sure of the Task Force width ranges at this time. Contributing information were Bob Welch, J Forbes and various locations throughout the Web and Automotive Magazines. Rear Axle Measurements MEASURED ACROSS WHEEL MOUNTING SURFACE 56 1/2" 71-77 Ford Maverick 8", 57" 71-74 V-8 Mavericks 8", All '75-77 6's & 8's Maverick 5 Lug 8", 49-51 Ford, 57-59 Ford 9" 57 1/4" 64 1/2 - 65 Mustang 58" 78-88 Mid sized GM Car, Malibu/Monte Carlo (82 up Metric Studs), 80 Granada & Lincoln Versailles, 67-70 Mustang/Cougar/Fairlane, Regal with 10 bolt axle, S-10 P.U., 65-67 Nova 58 1/2 " Ford Grenada 59" 68-83 Corvette 60" 55-64 Chevy Car, 67-69 Camaro, 64-67 Chevelle, 68-74 Nova, 71-73 Mustang/Cougar, 84-95 Corvette 60-61" 64-69 1/2 ton 2wd Chevy/ Some GMC 6 lug rear end 12 bolt Coil spring set up Possible gear ratio's 3.70 62" 64-77 Chevelle, 73-76 Torino, 89 Trans Am, 70 2wd 6 lug rear end 12 bolt Possible gear ratio's 3:08, 3:40, 3:73 70-81 4wd 6 lug reared ............................................................... 71- Newer 2wd trucks use a 5 on 5 lug pattern 71-76 Full Size Cars " "" "" " 60" 60's GMC and some Chevy's Dana 44 or Dana 60 with leaf springs 6 lug, Gear ratio's 3.21 to 3.92. GMC V-6 used a 3.21 Dana 44 used a standard chevy 1310 yoke, Dana 60 used the heavy duty yoke which takes the larger 1350 yoke. Approximate rear end widths measured from backing plate to backing plate. Add Width to compensate for drums as follows: 4" - 5" for small cars 5" - 6" for intermediate cars 6" - 8" for large cars 48" - 49" 50" - 51" 52" - 53" '71 Colt '72 Cricket '72-75 Datsun Pickup '72-73 Mazda '65 Ram American '74 Valiant '28-40 Ford , '57 - 59 Ford '62 Buick Skylark, '67 Chevrolet Six '67 Mustang Six , '68 AMX '69 Javelin Six , '70 dodge '70 Duster , '71-77 Maverick '71 Comet , '71- 72 Pinto 54" -55" 56" -57" 58" - 59" '39 -48 Chevrolet, '68 GTO '41 -48 Ford, '68-72 Chevelle '55 -57 Chevrolet, 68-69 Fair lane 6 or 8 '66 Falcon, '69 Chevrolet '67 Mustang V-8, '69 Firebird '69 Cougar, '71 -73 Nova '73 Ventura, '73 Mustang '36 Plymouth, '54-56 Ford Pickup '67 Lincoln, '69 Dodge '69 Dodge Van, '71 Torino '72 Cougar, '74 Pontiac '49 Plymouth, '61 Chevrolet Impala '65 Cadillac, '66 Buick Wildcat '66-67 Chevrolet Big Car, '72 Charger '69 Oldsmobile 88, '72 Chrysler '72-73 Torino STOCK CENTER TO CENTER SPRING PERCH DISTANCE 25" 39" 42" 42 1/2 '68 - 72 Chevelle '71 Colt '73 Mazda '68 -71 Fairlane/Torino '49-51 Ford '69 Chevrolet '69 Nova '71 - 72 Pinto '73 Ventura 43" 43 1/2" 44" 46 1/4" '65 Ram American '64 1/2-'65 Mustang '67 Mustang '70's Ford Grenada '69 Firebird '70 Dodge '71-77 Maverick '70 Duster '70 Nova '71 Comet '72 Dart '72 Cougar '74 Valiant '57 Ford '67 Chevrolet Six '68 AMX '69 Javelin Six '69 Dodge 47 1/2" 48" 51" 57 1/2" '39 -48 Chevrolet '67 Chevrolet big car '72 Charger '72 Chrysler '69 Dodge Van '69 Ford Van '67 Lincoln BACK TO TOP OF PAGE ________________________________________ The following list of extensive information was contributed by R. Welch: Original Vehicles Rear Suspension Width (Flange to Flange) Year Classic Vehicles Width 26-39 Plymouth-Dodge car/pick up 56-58" 40-52 Plymouth-Dodge car 60-62" 26-39 Chrysler/DeSoto Car 60" Most Early Mopar's 56-62" 25-39 Chevy Car 56-58" 26-46 Chevy Truck 56-58" 40-48 Chevy Car 58-60" 49-54 Chevy Car 58-60" 47-54 & 55 1st Series Chevy Truck 60-62" Most Early Buick,Olds, Pontiac 58-61" 28-31 Ford Car/Pickup 57 1/2" 32 & 33-34 Ford Car/Pickup 56 1/2" 35-48 Ford Car 57-60" 35-41 Ford Pickup 56-60" 49-58 Ford Car 57-58" 49-56 Mercury 57-58" 49-51 Mercury 61" 64 Falcon 58" 67 Cougar 60" 55-59 Chevy Pickup 62"
Donor Vehicles Front and Rear Suspension Width (Flange to Flange) Year Classic Vehicles Width Front Width Rear 74-79 Ford Mustang II/Pinto & Mercury Capri/Bobcat 55 ½" 55 ½" 71-77 Ford Maverick with 8" axle 56 ½" 75-80 Ford Granada with 8" axle 57 ½" 64-66 Mustang 57" 67-71 Mustang 59" 72-73 Mustang 60" 67-69 , & 60" Camaro 60" 64-67 Chevelle 60" 55-64 Chevy car 60" 65-67 Nova 58" 68-72 Nova 60" 60" 78 & up Monte Carlo, Regal, etc. with 10 bolt axle 58" 58" 68-72 Chevelle with 10 bolt axle 61 ½" 89 Trans AM (Disc brake) 62" 76-80 Camaro/Firebird 61 ½" 60 ½" 68-83 Corvette 58 ½" 59 ½" 84-95 Corvette 59 ½" 60 ½" Early 70's "A" body (Dart/Duster) with V8&3/4 axle 58" "E" Body (Cuda) with V8&3/4 axle 58" Dodge Dart 59" 55 ½" Plymouth Volare & Dodge Aspen 61" 60 ½" 71 Blazer (6 lug) 63 ¾" 75-78 Granada 9" (43" perch to perch) 52 ¼" 75-78 Maverick 9" (43" perch to perch) 56 ¼" 81-87 Olds Cutlass 58 ½"
FRONT SUSPENSION INFORMATION Track Width of Popular Donor Car Clips Manufacture Model Years Track Front/Rear Curb Weight Chevrolet Nova 68-74 59.8-59.6 3,770 Buick Apollo 68-74 59.1-58.8 3760 Pontiac GTO 68-74 59.9-59.6 3880 Chevrolet Corvette 68-83 58.7-59.5 3655 84-95 59.6-60.4 3890 Chevrolet Camaro (Z28) 76-80 61.3-60.5 3820 Pontiac Firebird (TA) 76-80 61.3-60.5 3900 Ford Mustang II 74-79 55.6-55.8 3305 Pinto 74-79 55.6-55.8 3305 Mercury Capri 74-79 55.6-55.8 3305 Bobcat 74-79 55.6-55.8 3305 Chevrolet Monte Carlo 78-86 58.5-58.8 3235 Buick Century 78-86 59.0-58.8 3700 Pontiac Grand Prix 78-86 58.9-59.0 3735 Plymouth Volare 75-79 61.0-60.5 3395 Dodge Aspen 75-79 61.0-60.5 3395 Dodge Dart 76 59.2-55.6 3600 Table taken from "How to Build a Custom Classic Truck" Peterson Publication; June or July 1999 Written by: Don Emmons & Mike Briggs
Want to know about swapping out a rear end. and what to use Here's food for thought.... on 50’s chevy’s By: Jim Forbes
The 82-newer Camaros are wider than the older ones, so you should stick with the 70-81 models. The 75-79 Nova uses the same rear as these older Camaros, I believe. The 68-74 Nova chassis is the same as a 67-69 Camaro; the 75-79 Nova chassis is the same as the 70-81 Camaro. The 82-newer Camaros used the small 7.5" rear-end design that the 78-newer Malibu/Monte Carlo/regal/cutlass etc used, but it's quite a bit wider. Some of the 82-newer Camaros used different rear ends, such as the Dana 44, and some weird Australian rear-end. Of course, if you want to make sure, get out your tape measure and check yourself! I may be wrong. Here's another one from Jim on the subject---- There are lots of rear ends available! Some fit better than others. For 6 lug rear ends, the 64-69 1/2 ton 2wd Chevy (and some GMC) trucks have a 12 bolt rear, about 60-61" wide (I measure them where the wheels bolt on). The 70 2wd and 70-81 4wd have a 6 lug 12 bolt that is a couple inches wider, but will fit under an Advanced Design or Task Force truck as long as you don't get too wild with wheel/tire width. The heavy duty models have a 2.75’’ brake shoe, that’s stopping power. The 12 bolt truck rear ends from the 60s usually had 3.70 gears, which is a bit much for extended highway driving at 75 mph. You can swap the differential carrier and ring/pinion gears from a later TRUCK or VAN 12 bolt, the 70s trucks usually had 3.08 or 3.40 gears. Of course, you'll need to know how to set up ring/pinion gears, bearing preload, and all that other neat stuff to do this. These 60s truck 12 bolt rear ends are from coil spring trucks, so the perches are in the wrong place, and they have some extra stuff on the housing for a panhard bar, which you won't need with leaf springs. Most 60s GMC trucks, and some Chevys, had Dana 44 or Dana 60 rear ends, and leaf springs. These rear ends are 6 lug, about 60" wide, and will bolt into a Task Force truck (with some fudging, the perches are about 1/2" too far apart). The brakes use different parking brake cables, which is a problem, and the drums have a different offset. Gear ratios range from 3.21 to 3.92 normally, the 3.21 is found behind some GMC V-6 engines, and is a nice ratio for an old truck. The Dana 44 uses a standard Chevy 1310 yoke, but the Dana 60 uses a heavy duty yoke, which takes a larger 1350 series ujoint. A similar Dana 40 rear-end was available as an option in 59 Chevy trucks, equipped with positraction...rare, and with a 3.92 ratio. I have one of these rear ends; it was in my extended cab truck...I'm saving it for when I build a race truck (one of these years). The 71 and newer 2wd trucks use a 5 lug 5" bolt pattern, same as the 71-76 full size cars. There is not much available in the way of matching front brake rotors that will fit an old truck, so this rear-end is not too popular a swap, unless you get the 70-up 4wd 6 lug axles. Chevy also used 10 or 12 bolt rear ends in lots of cars, in varying widths. The heavy duty models have a 2.75’’ brake shoe. A common one is the 61" wide 70s vintage Camaro/Chevelle/Nova (and clones) 8.5" rear-end. In Camaros/Novas it has leaf springs, but the perches won't work with old truck springs. In Chevelles, it has coil springs, with lots of extra brackets to cut off, and the cast in mounting "eyes" on top, where the upper control arm bushings fit. Wheel bolt pattern is 4.75", and there are front disk brake kits available to match, or you can use the 53-54 car front hubs/drums on the original 50s truck brakes, to get the same bolt pattern front/rear. This is a good rear-end for using in an old truck, the ratios are commonly 2.73-3.36, with higher gears available. The axle shafts are usually worn out in these things, so check them (pull the cover, lockpin, and C clips out to get them loose) where they ride in the wheel bearings...before buying the rear-end! The 55-57 Chevy car rear-end is almost a bolt in, the perches need to be relocated to the top of the housing though. It has the 4.75" bolt pattern, and ratios are usually 3.55-3.73, but sometimes you'll find a 3.36. The 78-88 mid size GM cars use a 7.5" 10 bolt, which is about 58/5" wide. This rear-end would work well in an early (older than 47) truck, but it is quite light duty. Ratios are usually 2.29-3.23, which means you want some torque in the engine to pull it...but rpm will be low. This is a coil spring rear-end, with all the mounting brackets that need to be cut off. The Ford 8" and 9" rear ends come in a whole bunch of varieties, and only a few are useful in oletrucks. The late 50s full size cars have a nice one, but it's not easy to find brake hardware, drum, etc anymore. The mid 60s midsize cars, such as the Fairlane, have a rear-end that is about the right width, and would be a good candidate...if you can find one. The Maverick/Granada is very narrow, about 56.5", and would not fit anything but a very early truck, or perhaps a tubbed Pro Street truck. The 60s full size Ford car rear ends are usually too wide, but if you find one, measure it and see! Most earlier full size, and all mid size, cars use the 4.5" bolt pattern, while later full size cars use the 5" pattern. The Ford trucks have a big 5 on 5.5" pattern, with a big center that takes some work to redrill to anything Chevy. Ratios range from 2.47 to 4.30, and the axles come in 28 or 31 spline varieties. There is lots of interchange possible with the 9" rear-end, which is why it's so popular...I have one in my 55 Belair, and in my 57 Suburban chassis. Unfortunately, they are getting expensive, especially when you have to shop around for just the right one that will fit. So...if you don't know if a rear-end will fit, or what it came from, get out your tape measure and see for yourself! The most important things are overall width, and wheel bolt pattern...then concern yourself with ratio. I like a 2.75-3.0 ratio for a V-8 powered truck that will spend lots of time on the highway; about 3.2-3.7 for a 6 cylinder or small V-8 for in town and limited highway use, and the stock 3.9-4.56 ratio is great if you have to use your truck to haul lotsa weight, and you don't have much engine...just don't plan on going much faster than 55!
if this isn't enough i have more or you can find all this on the net hope it helps someone
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I did a drivetrain swap using a 1980 4X4 suburban to a 1956 GMC suburban. Both trucks were 34". Keep the old frame for sure. Whole lot better. Adapt axles to frame. Wheel back spacing can help if too wide. Many components will stay on old frame (the list is a mile long). The main fab is limited to engine mount, tranny mount, steering hook up, spring hangers/shackles fab and driveshaft shortened. Both the 80 4x4 and the 1956 were leaf spring all four. Since you have both vehicles like I did, you can take both bodies off and really plan it all out looking at both frames. Keeping the straight axle (adding PS and disc) or doing a 4X4 is way easier than a clip.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Wheel back spacing can help if too wide. buy the vendors standard kit but to me it's STILL not FAR enough back to center the axle. so here is a way to accomplish this http://s67.photobucket.com/user/1951otter/media/Scan1_0001-1.jpg.html?sort=6&o=336
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | He was talking about the wheel measurements, backspace is the distance from the wheel mounting face to the back edge of the wheel. It seems like you're talking about moving the rear diff front to back? Maybe I'm just not getting what you're saying. | | |
