1 members (TexasA&M48Truck),
190
Mod | | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | Can i put 1940 4 speed trans in 1950 half ton by using a 1940 bellhousing.i do have the have the the 1940 trans.if this is do able,i would get a 1940 bell housing.my 3 speed 1950 trans has had its better days.i notes the bolt pattern was a little narower on the 1940 trans left to right.this truck is nothing special i just whant it fuctionable.thanks | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You will find the 1940 transmission is much shorter than the 1950. Rebuilding the 50 trans is fairly easy.
See the USA in your vintage Chevrolet! My Blog | | |
