0 members (),
68
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | ok i finally was able to remove the hosuings for the cab lights, cleaned around the base, had 2 bulbs that were out, got new bulbs, now only 1 lights up??? contacts inside where the bulb go's looks good and clean... cant get to the base mount screws unless i remove the headlinner,. any ideas why i have only the center light working??? also were these add on cab lights wired into the light switch attached to what side??? | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Try running a temporary ground wire(a jumper cable works)to ground the housing to the negative side of the battery.They were wired down the left pillar post and fused to the hot side of the light switch.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | thanks, ill try it, was trying not to remove the headliner but guess ill have to, the bases are pretty rusty, but i have to get them working the one so far makes the truck look cool, ill try the jumper ground, | | |
