Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (41 chev, klhansen, ArtA), 138 guests, and 2 robots.
Topics128,290
Posts1,058,564
Members48,492
Hey guys, the main cylinder to the brakes is leaking badly.
The brakes are gone! The main cylinder leaks so I bought a repair kit from eBay. No instructions though, so I wonderd, is this easy to fix? How do I remove the cylinder? What should I think about? The large rubber thingy that goes over the axel where the pedal is linked to is gone, and that's were is leaks, so my guess is that the rubber on the piston is gone as well.
Is there a walk through with pictures somewhere? Or could anyone explain how to do this?
the brake repair kit
Chevrolet 3100
Year: 1951
engine: inline 6 217CI
Transmission: Manual 3-Speed.
12Volt.
Hey,
Should just be two bolts holding the master cylinder to the drivers side of the frame. Carefully take the brake line off the back then disconnect the front linkage. As you disassemble the cylinder, just lay out the pieces as they come out. It's pretty simple to do just take your time and keep everything clean. You will probably have to get a brake cylinder hone and and hone the inside of the master cylinder. If it's pitted badly, you will need to have it bored out and sleeved or find a different one.
Bruce
My Trucks
Stuff I Collect
Thanks, you really think its that bad on the inside? it worked great until the car just stood in 2 years and i tried to push the brakes.. Well i'll take it apart and change the whole inside! Thanks a lot for your explanation!
Chevrolet 3100
Year: 1951
12Volt.
It might not be pitted but only full of crud. You won't know until you take it apart.
Bruce
My Trucks
Stuff I Collect
I just went through all of this and found that my master cylinder was to pitted to reuse after honing. I bought a new one off of Amazon of all places for $71.00 shipped. Make sure that your brake lines are in good shape as well - I am changing all of mine to NI copper.
1950 3600
1951 4400
Gazz
Brake lines were replaced a couple of years ago so they should be fine, I'll take a look this weekend!
Chevrolet 3100
Year: 1951
12Volt.
So i took it apart this weekend, looked really nice on the inside (forgot to take a picture) cleaned it up, and the inside was smooth as a babys butt, so i just put in the new parts, filled it with brakefluid and now it doesnt leak and works great! Was a piece of cake! Thanks for all the info!
Chevrolet 3100
Year: 1951
12Volt.
Carefully remove the old 1 , then throw it away , then buy a new \one ....
" STUCK IN THE '50'S "
