7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible), 88 guests, and 1 robot.
Topics128,074
Posts1,055,910
Members48,429
#10157 06/15/2003 7:25 AM
Well, I lost the link you had that showed a governor. Vacuum-spinner I think you called it. From memory I think it looked different from mine... don't see a dashpot. How many kinds are there? How do they work? Thanks for the help.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
#10158 06/15/2003 8:32 PM
STEBRT3 - was a pic I put up from my manual, and prolly deleted it now!! according to the task force manual there's 2 types, the "velocity type" which is an adjustable unit that goes btween carb and manifold and limits engine speed by limiting intake flow velocity - it was standard on school buses and optional on any other 6cyl, maybe what you've got
2nd type is "vacuum spinner type" was on all 5000 - 10000 series w/ V8, and it is 'mechanically driven vacuum actuated mechanism' that limits engine RPM to 4000 max under full load conditions - this type has a throttle-body unit and a distributer unit which are connected by tubing - when dist is at certain speed it allows vacuum actuation of a butterfly below carb - type that was on the 58 283 I got awhile back
I can scan and send ya the man pgs if ya want - myself, I'd remove it all, unless ya don't trust yerself to avoid street racin w/ a full load!! grin
#10159 06/16/2003 4:00 AM
Thanks a million for the help. After looking a little closer, it appears that my monster likely has been modified...
There's a plate toward the front of engine closing off/covering an opening. I'll look closer & let you know what I find.
SO LITTLE TIME!
Is it possible to go ahead & scan that diagram again for me? Thanx!
