3 members (RLB, qside, Gray_Ghost), 71 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#1015793 03/21/2014 2:30 AM
I bought new floor seal and flange for the steering column of 57 3100. New ones have a larger hole than the steering column diameter. I understand it needs to be slightly bigger to be able to slide the column through the seal, but there is probably 1/8" to 1/4" of space completely around the stock column that is not sealed. Am I missing something here??
the rubber covered metal piece should have a loose fit, but the actual seal should be snug - if not you might have bought from the wrong place ohwell
Sir Searchalot
Sir Searchalot
This is what you are missing. Either under carpet/matt or under hard seal. http://www.classicparts.com/1955-59...ge-Seal/productinfo/40-213/#.Uyuclo2DTX4
I bought that same part from Classic Parts. The hole in the sponge seal is the same size as the hard rubber flange. Guess I'll buy another and see what I get.
Moderated by  ndkid275, Phak1
