6 members (TexasJim50, Stovebolt48, 32Fordpuchoptop, lumbersawyer, JW51, 1 invisible), 56 guests, and 0 robots.
Topics128,080
Posts1,055,945
Members48,430
#10152 09/12/2002 2:25 AM
hey fellow stovebolter's I need some help once again. This is the situation....I have a chevy 250 in a 54 chevy 1/2 ton with a 2004r tranny. I need to find a floor shifter that will work with that tranny. Does anyone know of a donor vehicle that I can borrow one from. I know I could spend 250.00 for on of those lokar or genie floor shifters but, the funds are not available for the purchase yet. My sister is getting married and I want to arrive in true classic american style-screw the limo....Any help will help.
Thanks in Advance guys and gals,
Marlo
#10153 09/12/2002 5:01 AM
I think you should be able to check with a wrecking-yard and they will be able to tell you which vehicles came with that tranny and a floor/console shifter.Some yards will even give you a better price if you pull it.(Some do not allow people inside the yard itself)
#10154 09/13/2002 6:14 PM
thank you machainiac I tried a few local yards and they had nothing ....I will still try and look around .
#10155 09/13/2002 7:03 PM
The 2004R is a 4 speed auto tranny made by GM. It was used in mostly BOP cars with v6 engines. Most had a BOP bellhousing, but some had a universal that would fit either the SBC bellhousing or the BOP. This tranny was most famously used in the mid-80s Buick Grand Nationals and T-types, both of which had the screaming 3.8 turbo V6. Check to see if the GNs or T-types had floor shifters. Most aftermarket shifters won't work with an automatic with 4 forward gears.
Let me know what you find, as I'm gonna do a similar deal with a 2004R behind a Poncho 400 in a LeMans.
Good luck
Chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#10156 09/14/2002 2:09 AM
Marlo-if you're wanting a stick-type shifter with pushbutton knob, look for 1982-1985(?) Monte Carlos with buckets/console. Chip-does your LeMans have a "horseshoe" type shifter like similar year Malibu? If so, check for late eighties/early nineties Pontiac Bonneville. I'm pretty sure those cars had a horseshoe type auto overdrive shifter. Hope this helps.
Wannabe smile
"Don't expect anything and you'll never be disappointed"
