4 members (TUTS 59, Shof, Ponchogl, Jon G), 172 guests, and 3 robots.
Topics128,094
Posts1,056,157
Members48,436
#1015367 03/19/2014 11:27 AM
A couple have already twisted off,not gonna put the old ones in the new engine.Are these special bolts of any kind,and if not,what what grade are they?
Grade 5 should work.
Drew
Thanks,kinda what i was thinking.I will coat them in anti seize also.
Instead of bolts, you may want to consider installing studs. Studs make the installation of the manifolds a but easier, plus they are a bit stronger as well.
For anti seize, I would suggest that you use the copper based one if you can find it. The copper base anti seize holds up better on high temp applications such as exhaust.
Bill Burmeister
The copper base is what i use.May consider studs.
