3 members (Bill Hanlon, 66flea, 55shaker), 90 guests, and 1 robot.
Topics128,052
Posts1,055,725
#101530 07/09/2007 6:51 AM
I filled the 67 chevy up yesterday after work, and drove home. The float has a hole in it, so I pulled the unit that night. I'm kinda concerned because the rheostat(?) part was completely submerged in gas. I'm wondering if this is normal. When I had my 62 GMC I was always worried about that thing shorting out and causing an explosion. Is there a chance this can happen???
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
that's normal.
Ex Hall Monitor
Ex Hall Monitor
Ditto. No danger of explosion from the sending unit when wired normally.
