7 members (Philipj, CharlieF, CATMAN, klhansen, fonz8261, Shade Baby, Phak1), 84 guests, and 2 robots.
Topics128,153
Posts1,056,842
Members48,456
I once repaired the cracks in a Jaguar 120 steering wheel with just body filler and thick grey primer. It looked great when finished in gloss black, but I never got to see it years down the road. On my AD I'm trying this Loctite epoxy gel into the cracks after I ground out a groove for it to sit in. I was told this stuff will sit tight and not run away on you. Any input, should I go ahead, or are there better ideas around? Steering wheel
Have you ever noticed that anyone driving slower than you is an idiot and anyone driving faster than you is a maniac? - George Carlin
I used JB Stik epoxy putty. It stays where you put it and sands just like the material the wheel is made of. Easy to work with.
Thanks, the Loctite epoxy is working well, but requires my 90 degree die grinding sander to get thru quickly. I've only done the backside of the wheel so far, I'll try the JB on the front next.
JAW Offline
Most likely I'm too late with this post...
But, I used POR 15 Epoxy Putty to fix the steering wheel for my 54' Chevy. It worked great, easy to apply and sand.
I've used plain old JB Weld, but V-d the crack and drilled small divot-like holes in the crack sideways to give it somewhere to creep into and try to get a toe hold. So far, so good, 2 wheels nearly a decade ago.
Moderated by  ndkid275, Phak1
