| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 82 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 82 | I've recently obtained a set of 2004 lesabre seats and was wondering if anyone had any pointers on installing them in a 54 chevy. The width is perfect and the built in seatbelts are great. Just wanted someones experience before I start cutting and fabbing. Thanks! | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I haven't done that exact install, but have used modern seats. My best advice is to block the seats up to determine the height you want, then make some kind of mount that goes between the buick seat frame and your trucks floor. I used 4x2 steel tube, 2x2 steel tube, and angle iron That way if you need to change or adjust something in the future, you can just adjust the frame you made and the frame of the Buick seats are not messed with. I say this assuming you'll need to mount the seats high off the floor, since where you'll want to sit in your '54 is much higher than where you would sit in a 2004 LeSabre. | | | | | Joined: Feb 2000 Posts: 120 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 120 | Hey, New Ton
Love the 9' box on your '54. I have also installed '04 Buick seats in my '54 3800...check out the pics in my 3800 Photobucket.
I used all scrap uni-strut from a hospital Xray demo job. I have more pictures. I didn't upload them all, if needed
I like sitting higher in the truck. Any question let me know.
Jim D. 1954 44001954 3800Jim D. '41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck '54 Chevy 3800 Dump........New Truck! '54 Chevy 4400 flatbed/dump, Gone to my brother-in-law '13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles '01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
| | | | | Joined: Sep 2011 Posts: 82 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 82 | Jim,
Thank you for the pictures, they are very informative. I see that you relocated the fuel tank to make more room for the seats. I might need to look into doing that as well. Thank you again!
- Allen | | |
