9 members (Bill Hanlon, 1955 1 Series, dt235sd, mo2cyl, FAST55, Steelonsteel, MikeE, sron48, klhansen), 75 guests, and 3 robots.
Topics128,050
Posts1,055,667
#1005888 02/10/2014 5:11 AM
Anyone try the door latches for the 1949-1951 Truck from Goodmark Industries? I've used there body sheet metal panels in the past with GREAT success, but have tried there door latch assemblies.
1970 VW Beetle
Goodmark is just another brand of offshore parts. I think most of it comes out of the same factory. Right now, all of the sheet metal is pretty good. I don't think any of the repop latches are really very good.
V
V Offline
If you are someone with mechanical skills, you might consider doing what I did. I knew the originals were well worn after 60 years use. I couldn't keep the drivers door from sometime swinging open while driving! Now I was seriously considering ordering some aftermarket latches. After reading some of the past post on aftermarket latches I decided to have a closer look at the originals. What I found was that the ratchet part with the teeth was worn down. I mounted the latch in my vise and removed the rivets that previously held the ratchet portion of the latch. Carefully filled in the worn down teeth with a little wire feed weld. Using the pass/side door latch as a pattern I re-traced the new tooth pattern on the drivers side ratchet. I easily refilled all the teeth back in. Re-assembled everything. Man what a difference!!! the door stayed closed and was fairly easy to adjust.
Hopefully this will help
http://www.classicparts.com/1947-51-Door-Latch-Left/productinfo/18-521/#.UvkjUmyYbIU
Awesome.. thumbs_up
Purchased the latches from Goodmark and as anticipated and as stated by other Stovebolters, they did NOT work!! Bought a set of NOS GM latches and they work beautifully!! These latches from GM also fixed my passenger door latch from scraping the stiker on the bottom. My old latch was broken at the latch cage weld causing it to deform and move when I closed the door. I am also a firm believer in NOS parts. These aftermarket latches ARE JUNK!!
1970 VW Beetle
Where did you find NOS latches? root
I found the NOS door latches on E-Bay. They were pricey...but they work!
1970 VW Beetle
