| | | Forums66 Topics128,284 Posts1,058,526 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 22 | Hey guys I'm sure this topic has been discussed already. I've searched a lot. I need help. Found a 51 and going to check it out today. It's 2 hours away from me. The guy does not know if it is a 3100 or 3600. I'm looking for 3100. The question is say it's a 3600... Will the cab and fenders be the same? I am looking to restore it pro street style. I also read that the grill on a 3600 is spaced a little wider than 3100. All I know is that it's a short bed and does not have the dent on the rear fender for the spare. Thank you guys in advance. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Cab and fenders are the same the 3/4 ton will have a longer box on it with an additional set of stake tubes and longer frame (wheelbase). Grill is the same. You don't get into different sheetmetal until you get above 1 ton. IMHO
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2014 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 22 | So what you're saying is that if it's a short bed it's a 3100. I'm worried about just the body as that is all I'm going to use from it. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Yes, 3100 is a 1/2 ton (so it's the short bed) and 3600 is a 3/4 ton (so it's the long bed). There are no differences other than suspension and bed length/wheelbase. | | | | | Joined: Mar 2014 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 22 | You guys put my mind at ease... Thank you for your time once again. | | | | | Joined: Mar 2014 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 22 | Well.... He wanted to sell me the truck and they couldn't find the title... He wanted to give me a bonded title... I walked away... Told him that if he finds title let me know... | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Tiddlar, did the truck have a body tag on the driver's door with a VIN? 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2014 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 22 | Tiddlar, did the truck have a body tag on the driver's door with a VIN? . Yes it did..... | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Then I wouldn't necessarily rule out the sale because of a bonded title if you really like the truck. It is always a concern about buying a truck without a title, fearing it being stolen. But I can see how titles can get lost too, especially if the truck has been in a sole's possession for a long time or passed down to a family member or part of an estate or so on. Another thing that makes it hard to legitimize the truck is the fact that some states actually titled the trucks with th VIN being the engine number and not the body number on the door jamb. So you have a engine failure in 1955 and someone puts in a replacement engine 50 years ago and your title no longer matches and nobody is the wiser. Has it been stolen- no but there sure can be some suspicion cast to a future buyer.I was in the same boat last year when I bought my 53. Truck had a 235 in it and the title number did not match the door VIN tag. Luckily the owner kept the 216 with the correct number to substantiate authenticity. Anyway my .02
| | | | | Joined: Mar 2014 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 22 | And I highly appreciate those 0.2. Well the owner of the truck supposedly is in jail. With a bonded title, I buy the truck... Put in 5000 worth of work, the owner can take the truck whenever within a three year period. It just all sounded too shady. And yes titles get lost but I'm just too cautious... | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's not true about a bonded title. The whole purpose of issuing the bond is that a title search would have been completed and no owner found in addition an appraisal by a bonded appraiser would have been submitted and the bond issued in the appraised amount, normally by an insurance company. After a period set by the court, usually two years, if no one claims the vehicle then it is yours free and clear. If a claimant does come forward within that period then the claimant gets the bond and the vehicle is your free and clear. I'm sure there are variations in different states but that is the general format. I had a friend once that went thru the process here in Illinois and now owns the vehicle with a clear title. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Understand. Sounds pretty sketchy. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
