| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10145 01/04/2003 1:46 AM | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | When wheel cylinder sleeveing is done what is used to afix the sleeve in the cylinder? :confused: | | |
#10146 01/04/2003 4:58 AM | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | I dont know what you are working on, but BUY NEW ONES. They are not that expensive and its YOUR HIDE thats riding on a patch work brake job! Try your local NAPA or any of the old parts places. Brad | | |
#10147 01/04/2003 5:09 AM | Joined: Feb 2000 Posts: 987 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 987 | From what I now they use stainless steel sleeves and the are pressed in place. This is a viable option if you cant find a new w/c.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#10148 01/05/2003 3:43 PM | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | Thanks for THE replies BUT Would the pressed in sleeve seal well enought to keep brake fluid from seeping? OR /and do they press fit and sweat fit with BRAZING OR SILVER SOLDERING? | | |
#10149 01/05/2003 7:15 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | There is a company with a web-site that explains the process. I can't seem to recall who it was though. Seems it was the one that does brass liners and not the stainless of White Post type. Maybe if you check some magazines for an ad. I remember they exlplain doing stepped units and disc type and lots of stuff. Sorry, CRS is setting in big time here! :rolleyes: :p
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#10150 01/06/2003 3:09 PM | Joined: Feb 2000 Posts: 987 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 987 | T-Ruck what year truck are you trying to repair/replace? Unless you have something that is very rare W/C should be available and usually cheaper then sleeving. Let us know I am sure we can help you find a new replacement.
