1 members (Peggy M),
74
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 25 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 25 | I have a 51 chevy, and my on/off switch for the starter in the cab has a short in it. I bought a new key cylinder from Chevy Duty. How does the the old cylinder come out, and the new one go in? The old one has 1 tiny hole in it, and the new one has two tiny holes. Is there a tool to pull the old one out, etc? THANKS!
Bernard Laiben 1951 3100 Chevy Deluxe Pick-up (original with 73,000 miles on a "straight Six" 216)
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | blaiben,
I haven't done it, but I think the tool is usually a paperclip! My question is, did you address the electrical switch/contact portion of your ignition switch. This is separate from the tumbler, which has no bearing on 'shorts'.
Stuart | | | | | Joined: Feb 2001 Posts: 25 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 25 | No, I did not know there was more to it than the tumbler! When I turn the key on, it usually turns on (the guages move), but then it'll usually come disconnected and goes off. To get it to work I have to turn the key about half way on, and it gets a good connection. Then, I take my keys out of the tumbler when I'm driving, because the weight of the key chain will jiggle enough to "short" it out again, and "die on the run." This problem took my a while to figure out that it was just in the switch,and not my carburator or something more major! What do you think? THANKS!
| | | | | Joined: Feb 2001 Posts: 25 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 25 | By the way, I sprayed it real good with some contact cleaner, but that didn't seem to help.
I would guess your switch is just plain worn out...its 56 years young. Some of the specialty suppliers show 'ignition switch' which is different than 'ignition lock'. The lock part comprises the cylinder and keys. Maybe some lock-smart bolters will pop in soon.
Stuart | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | What you have is an intermitent "open" circuit, not a "short" circuit. A "short" circuit occurs when electricity finds its way to ground before going where it is supposed to go, thus taking a "short cut" to ground. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | drop by the local locksmith. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | I have a switch you can have.Free. PM me your name and address,ill send it to you. Just return the favor down the road to someone,someday. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Its in the mail this morning,,with key. Just a quick changeover and youre rollin.......... Good luck, Marty | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | The spirit of the Stovebolt....sharing! Marty knew that his key switched wanted to be used, not just sit in a box in the corner. Good for Marty. Stuart | | | | | Joined: Feb 2001 Posts: 25 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 25 | Marty - I recieved the switch, and installed it, and it works great!! I even took the truck to a cruise-in tonight at a local Hardees and the manager selected my truck as the best of the show!! It was the switch, I'm sure of it!!! Thanks a million, seriously....you're what makes Stovebolt so great.
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Youre sooo welcome,Bernard. Glad i could help ya............... I think we'd all like to see a pic. or two of your truck. Are you in the Gallery? Happy Truckin, Marty | | | | | Joined: Feb 2001 Posts: 25 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 25 | Yes, I'm in the gallery.....a 1951 called "The Grandma Proof Truck"...it was a featured truck about 5 years ago or so.
| | | | | Joined: Feb 2001 Posts: 25 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 25 | I realized today that after hooking up that "new" ignition switch I accidentally didn't hook the fuel tank wire back up.....oh well, another excuse to work on it!! If you're looking at the BACK of the switch, which one would the gas tank wire hook to? (the 10 o'clock, 2 o'clock, or the 6 o'clock??)
Thanks a million again for all of your help!!!
