7 members (chevy51truck, Gdads51, dt235sd, Otto Skorzeny, JW51, MickeyP, LAROKE), 62 guests, and 1 robot.
Topics128,049
Posts1,055,698
#10145 01/04/2003 1:46 AM
When wheel cylinder sleeveing is done what is used to afix the sleeve in the cylinder? :confused:
#10146 01/04/2003 4:58 AM
I dont know what you are working on, but BUY NEW ONES. They are not that expensive and its YOUR HIDE thats riding on a patch work brake job!
Try your local NAPA or any of the old parts places.
Brad
#10147 01/04/2003 5:09 AM
From what I now they use stainless steel sleeves and the are pressed in place. This is a viable option if you cant find a new w/c.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#10148 01/05/2003 3:43 PM
Thanks for THE replies BUT
Would the pressed in sleeve seal well enought to keep brake fluid from seeping? OR /and do they press fit and sweat fit with BRAZING OR SILVER SOLDERING?
#10149 01/05/2003 7:15 PM
There is a company with a web-site that explains the process. I can't seem to recall who it was though. Seems it was the one that does brass liners and not the stainless of White Post type. Maybe if you check some magazines for an ad. I remember they exlplain doing stepped units and disc type and lots of stuff. Sorry, CRS is setting in big time here! :rolleyes: :p
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#10150 01/06/2003 3:09 PM
T-Ruck what year truck are you trying to repair/replace? Unless you have something that is very rare W/C should be available and usually cheaper then sleeving. Let us know I am sure we can help you find a new replacement.
Brian Moore
