4 members (78buckshot, klhansen, 2 invisible), 147 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#101457 07/03/2007 2:49 PM
im working on a 48 loadmaster, all lights work but i cant get the instrument lights to come on, found 1 bulb broken, can the switch be messed up?? checked the dimmer on the switch, wont make a diffrence, ideas???? thanks guys.
nothin like ol' Chevy iron..keep it goin
1948 Chevy Loadmaster Flatbed
48loadmasterguy,
I don't know if this is accurate, but a wiring diagram I looked at shows the dash lights coming off a common light switch terminal with the taillight. If this is true, it would appear that if it were a defective switch, neither dash lights or taillights would work when switched on...if the taillight does work, then the problem would be bulbs or a poor ground for the dash lights themselves. This isn't the brake light, just the taillight.
Stuart
thanks stuart ill check it.
The instrument light feed goes through the dimmer rheostat and so that is part of the chain that could fail. Did you test the bulbs with and ohm meter?
1951 1 Ton Completed
