1 members (Rnl364),
104
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 7 New Guy | | New Guy Joined: Jan 2007 Posts: 7 | Hello everyone. I have a 1955 1st series 3100 with dealer installed turn signals. When I bought the truck all I had was the switch and housing (with lever)and wires going down the steering column.I purchased a dealer installed accessories manual and completed the wiring,changed the front single filament bulb sockets to doubles and installed a Bussman #535 6 volt flasher and pigtail.Wired 'X'to power,'L'to switch 'P'to indicator light on speedo and grounded flasher per manual instructions.Got all done and when lever is operated all the proper lights light up but don't flash and indicator light doesn't light up. What's up? I tried changing the flasher wires around but nothing.Any help will be greatly appreciated. Thanks.....Bob | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Double check your grounds, bad or no grounds make funny things happen. I've never heard of a flasher being grounded unless it's an LED flasher. Maybe try just grounding through the lights and see if that changes anything. | | | | | Joined: Jan 2007 Posts: 7 New Guy | | New Guy Joined: Jan 2007 Posts: 7 | When I installed the new front bulb sockets I soldered a ground to them attahed to mounting screws into body. I only grouned the flasher body in an attempt to solve the problem. But thanks; I will check the grounds (again).....Bob | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | When I was wiring my truck I had everything wired and working great, then the headlights and turn signals started acting funny or not working. My inner fender that my headlight relays are grounded to wasn't getting a good ground connection to the rest of the body. Also, I had a bad connection to one of my turn signal indicators on the dash, messing up my signals. Issues like that can take a lot of diagnosis to figure out the issue.
After that I learnt not to assume that grounding to a fender would mean the item was properly grounded. I'm not saying a ground is your issue, I'm just sharing my experience.
What bulbs are you using now? I'm wondering if you have enough load for the flasher to work.
| | | | | Joined: Jan 2007 Posts: 7 New Guy | | New Guy Joined: Jan 2007 Posts: 7 | I'am using wagner 1154's in both front and rear. | | | | | Joined: Jan 2007 Posts: 7 New Guy | | New Guy Joined: Jan 2007 Posts: 7 | Here's an added twist. I held the flasher in my hand,ran a short hot jumper wire from my battery terminal to 'X' on the flasher; ran a wire to the hot wire on a new socket and bulb to the 'L' terminal and then touched the socket to the ground terminal on the battery.The light lights up but doesn't blink. I even ran a ground wire to the 'P' terminal in another attempt to get something to happen but still nothing. I thought that maybe it was a bad flasher but when I had my friend at the parts store order the flasher he received two and complained that it would sit on the shelf forever, so I bought both. I switched the flasher and....NOTHING! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The bat voltage might be low with all this testing. Try charging the bat. or run the engine at a fast idle for a few minutes. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2007 Posts: 7 New Guy | | New Guy Joined: Jan 2007 Posts: 7 | Yeah, I checked that too during all of this; I got 6.33 volts. Thanks.....Bob | | |
