6 members (Gdads51, 3B, 32Fordpuchoptop, Bill Hanlon, Otto Skorzeny, Joe H), 166 guests, and 2 robots.
Topics128,110
Posts1,056,246
Members48,437
#1013883 03/13/2014 5:12 AM
what six prong spanner socket do I buy for the rear axle nut on a '49 5400. A Napa # would be keen.
Greg
1947 M15 Studebaker 454 4x4
1949 Chevy COE
More pix of the COE
1950 Harley FL
1958 GMC LCF 455 3x2bbl
1961 Chevy C60 Tilt Cab 327
1966 Chevy C60 Tilt Cab 496
1961 Chevy K10 sb 292
1974 Harley FXE
1979 Chevy K10 sb
2007 Harley Streetglide
I'm not that good but I'm slow
1949 Chevy COE
More pix of the COE
1950 Harley FL
1974 Harley FXE
1979 Chevy K10 sb
J M Offline
Check to make sure it is the right size. It says spindle nut for a 4 wheel drive. If I am thinking right this is a lot smaller then the rear axel nut on your truck. The OTC number on mine is #1930. It cost about $80.
Jim
Thanks Jim. Is yours 2 7/8 and look like this one ?
http://www.mile-x.com/otc-1930-spanner-wrench.aspx
Greg
1949 Chevy COE
More pix of the COE
1950 Harley FL
1974 Harley FXE
1979 Chevy K10 sb
That's nice looking with the pilot if it fits.
I've been using a cheap one I got at Advance Auto that happens to fit. It was listed/sold as one for a 4x4 front axle lock nut of some sort.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Yeah...if it fits. The pilot is what I'm concerned about. For the #1930 there is usually a note like this -
OTC 1930 Tubular Spanner Wrench - Wrench for servicing 1954 to current Chevrolet and GMC 11,000 to 13,500 lb. axles. Socket O.D. is 2-7/8".
I'm working on a 49. Any idea what is different on a 49-53 ?
Greg
1949 Chevy COE
More pix of the COE
1950 Harley FL
1974 Harley FXE
1979 Chevy K10 sb
No idea.
Don't lose sleep over this socket. Pull one nut off and take it to the auto parts store and match it up to an affordable socket. These nuts set the wheel bearing adjustment and the second nut is just snugged up to that, not all that tight really so you don't need a fancy socket. In most cases a hammer and punch or dull chisel will do the job; though a socket sure is nicer it needn't be fancy.
Grigg
---All pictures---
J M Offline
Greg
I checked my socket, and it is the one that you found the link for. I looked in the 1948-1951 truck manual and it shows the same Kent-Moor wrench for those years, so I believe it will work for you.
Thanks for the e-mail. I tried to answer it, and hope it went through.
Jim
The old fashioned way to do this was to stick an appropriate sized drift punch in opposing holes and then using a long screw driver as a lever to turn the nut. You may well find chisel marks on the inner nut where someone previously used a chisel to turn the hex hut. I recommend correct socket for the inner nut.
I just bought a tool for removing the adjusting nut from NAPA.
I was overcome with joy at finding it because I had been searching all over for it.
I took photos to share
http://s62.photobucket.com/user/DesertTruck/library/
not sure they will display I am new to photobucket
Gas Pumper
Gas Pumper
There are other tools out there besides a crescent wrench and a hack saw?
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
BFH and Band-aids are staples in my shop. And a cuss jar over-flowing with money.
Gas Pumper
Gas Pumper
Yeah, I made a HUGE mistake back when I was a toddler and decided to use Pennys for my cuss jar. Now, I got nothin! Beside the cuss jar is a gumball machine. But I DO have a crescent wrench and a slightly used hacksaw. smile I just use Duct tape for bandaids, hand sanding with the lower grits, and when I have a desire to add to the penny jar.
Deve
The Think Tank
I bought an axle socket at O'reillys. It had the right number of teeth, in the right places, but they were all too wide. They need ground down. So, back to the drift punch...
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
I have one. I sent you a PM.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
Moderated by  MNSmith
