7 members (55shaker, Jeff Ogden, RoadsScholar, Gray_Ghost, Ponchogl, fonz8261, 1 invisible),
82
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,722 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Hi All,
I have a set of valve stem oil seals (Carters ME5521) that includes O-rings and Umbrellas. I am adding these to a 216 head. Looking at prior posts and checking the old car manual site, I can't find a picture of how they're placed on the stem.
The '48 - '51 manual shows o-rings, and the '54 manual shows o-rings [/i]just below the keepers[i]. So, does the umbrella go first, just below the o-ring, or sitting over the end of the valve guide? Or does the o-ring go on, then the umbrella gets sandwiched between the o-ring and the keepers? I'm confused and would appreciate some guidance.
Thanks in advance for the help.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | I believe that you are supposed to use one or the other, but not both.
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Carl,
Thank you for the comment.
Is there a preferred seal to use? My gut feel would be the umbrella, but I would appreciate feedback.
Never, never, never, never give up. - Churchill | | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | One type is used on Intake and the other type is used on Exhaust. I don't remember which is which. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I'd be cautious of using umbrella seals on either. I know that some use them on the intake valves. I know that not enough oil for the valve stems causes more problems than to much oil. | | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | The umbrella seals that I use on my 235 are designed to ride up and down with the valve,once the valve has opened the seal is pushed up near where the o-ring seal would have been, they are not the style that are pressed down over the top of the valve guide and stay there. I have had no problems with this style of umbrella seals and I have been running them on intake and exhaust for 4 thousand plus miles.
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Thanks for the input guys. I'll let you know how it goes (later this spring).
