| | | Forums66 Topics128,190 Posts1,057,223 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | Hi Everybody I just found out a company is making for 8 lug front end (like my 1 ton) disc brake kits. I wrote to the fellow selling them and he says that they should work with the older 47-54 1 ton spindles. Does anybody on here know if they are the same part or not? Here is the link to the ebay ad:
http://www.ebay.com/itm/350973126802?item=350973126802&viewitem=&sspagename=ADME:X:RTQ:MOTORS:1123&vxp=mtr
I have been doing a lot of reading on this subject and it looks like maybe this will work. Any insight from you folks with more knowledge than me would be great...It would save me a lot of head scratching thats for sure.
MikeC 1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | No, not the same. The bearing diameters on the spindles are different between 52 and 53. See this bearing info https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=604816#Post604816That said the mounting ears on the spindle for the backing plate may or may not be different, and that's what matters I expect. You can probably get around any possible troubles by using the later model spindles and hubs if necessary on your older axle beam, the king pin diameter/kit should be the same. Ask the seller any questions but even if you try it out on your own I think it could be made to work if it's not a direct bolt on to the older axle. | | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | Hi Grigg
Thanks so much for that link. A lot of stuff on that thread for sure. I think I have skimmed over it before. I will have to take your advice and contact the seller once my truck gets to me and I can really look it over and make sure it is what is supposed to be. Yeah I saw ad of Ebay and I was thrilled to see maybe I would have a source for those caliper brackets already made.
This is going to be a fun rebuild I hope. My goal is a daily driver type vehicle with a modern braking system and a lower gear ratio for more traffic friendly driving.
