0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#101349 06/28/2007 3:27 AM
After adding on the common turn signal setup to my truck with mixed bulbs....fronts conventional and rear LED's, I found my emergency flashers wouldn't work although the turn signals functioned properly. I was using the "3 prong electronic" flasher. Changed back to a conventional 3 prong flasher and they all work as advertised.
Hope this helps someone avoid the same problem.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#101350 06/28/2007 7:58 AM
with led's need a resistor in line to have enough resistance to have HD flasher to work, Don't know the resister value needed...
GMC: Get More Cash...
1958 GMC
My Webshots photos
