2 members (Peggy M, MTD91),
141
0
Mod | | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | In the coming months I will be yanking my engine and trans to do some inspections on the internals. I'm wondering what silicon or rtv or gasket sealer you guys are using? Timing cover, intake manifold and oil pan. Right now my timing cover has a minor seepage. And it's been 2 years of abuse since last tear down. Motor is a small block.
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | None.
Make sure your timing cover flanges are in good shape and the torqued down properly. I have an 18in file I run across bolt on parts (that I can) and will work the high spots to get a good surface all around. There are a few youtube videos that show how to do this. | | | | | Joined: Dec 2008 Posts: 902 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 902 |
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | |
